97520H
520 Wiring Help Needed
97520H
I was mowing with my 97 520 a couple days ago and it shut down completely. I found the pins that handle the red wire in the 9 position engine harness (the connector directly in front of the battery) were a bit burnt. I spread the pin open a bit with a screwdriver and put it back together and it seems to be working fine for now. I would like to find a way to permanently fix this cleanly without resorting to butt connectors.
Toro sells replacement connectors for under $4 per side, but I'm not sure about attaching them to the ends of the existing harnesses. Has anyone had to do this fix before?
97520H
Thats just what I needed! I got one ordered. Thanks for your help!
