Electro12WH 50 #1 Posted April 22, 2010 The set screw on my trans doesn't have the point I'm familiar with. It has a straight unthreaded portion on the tip that goes into a straight hole on the shifter ball. How deep should I insert this pin? All the way? Share this post Link to post Share on other sites
rickv1957 72 #2 Posted April 22, 2010 You can screw it in untill shifter gets tight then back of a little allowing free movement,Rick Share this post Link to post Share on other sites
Electro12WH 50 #3 Posted April 23, 2010 Okay, thanks! Share this post Link to post Share on other sites
