stevebo-(Moderator) 8,742 #1 Posted April 18, 2010 Guys, I am looking for a good source to find a replacement ark loader valve. It is a dual set up. Mine is leaking and may be crossing due to a crack in the housing. Does anyone have a good used valve off an ARK loader for sale ? Thanks- Here is a pic of the old one. Share this post Link to post Share on other sites
Nick 13 #2 Posted April 20, 2010 Have you looked around www.surpluscenter.com ? A 2 spool valve with float, or maybe without a float if you dont use it, would probably be in the $125 to $200 price range. As long as its an open center designed for 2 way cylinders ity should work fine. Size and flow rates might be something to watch for along with an adjustable relief valve. Not sure how the size compares but this valve has float and also power beyond so you can add a hydraulic circuit for something else. https://www.surpluscenter.com/item.asp?item...tname=hydraulic Share this post Link to post Share on other sites
MalMac 1,337 #3 Posted April 22, 2010 When I thought my valve was bad on my ARK loader that I have on my C-141, which look just like the same valve in your pic. I took mine off and took it to a Hydraulic repair shop. I was lucky that it was not the valve. While I was there I did ask them if I had to replace it could they find one that would match it. They found an perfect match in a catalog they had there just a different manufacture. I can't remember the brand name. Anyway take it in and let them look at it. When it comes to hydraulics you can usually find the parts. Its a good thing Ark used pretty common parts. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #4 Posted April 22, 2010 guys i found a 2 spool with float on line burden surplus for 149.99. would rather have oem if anyone has one :omg: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #5 Posted April 22, 2010 nick, that is one of the 2 they have. thanks- Share this post Link to post Share on other sites
Nick 13 #6 Posted April 22, 2010 It wouldnt be Ark original and might not be cheap but you could also try KW manufacturing for the valve they use. Probably have to find a local dealer to get a price. http://www.kwmanufacturing.com Share this post Link to post Share on other sites
