Michael Bullington
312-8 Project
Michael Bullington
Got a New project to work on...This is my first time to own one of these models. The Rod is broke in the engine so...its time to pull it apart and see what happens!
horsefeathers
Stone Henge, Night photo is cool! Trees in back drop look like lightning! A good storm is brewing! Better take cover :omg: HORSEFEATHERS!
Duff
Michael, I've got your tractor's twin brother, and two slightly older brothers. I think you're gonna really like that machine.
I'll be following your progress closely, as I've had all three of mine apart all the way to the frame (one is still just a frame and a pile of parts awaiting refurbishing and reassembly). Fortunately, two of my three M-12's came in pretty good shape so I haven't had to open them up and thus can't offer any pointers or insights. The third is on the "to do" list with no compression but no clanking internally or parts in the oil pan to suggest anything is badly broken. Next winter's project!
Have fun! :D
Duff :omg:
rickv1957
Looks like a great project there!,Rick
Michael Bullington
Thanks guys after evaluating everything I have a few parts to replace,,,I do have a question about the tires..
The rear tires are a Armstrong Brand and the front tires are Carsile Brand,,,,Was this a common from the factory or did someone change mine.
One thing I really need is a seat...Does anyone have one is good shape for sale?
Thanks
Michael
Duff
Thanks
Michael
Michael, one of my 312's also has the Armstrong/Carlisle mix, but I got it second hand so I don't know if it was factory or changed. :D
As to seats, short of taking out a second mortgage, I'd look into a replacement from Lowe's, TSC or Fleabay. There were some threads about this earlier on. I got one from Fleabay and although it isn't WH or Toro branded, it fits, rides and looks great.
Duff :omg:
Michael Bullington
Got the ole 312 in the garage to do a good evaluation...Removed deck and hood to give it a good going over.
Need a new front tires...Rears are cracked but holding air -Should be okay
One spindle is been welded where is was broken- need replacement
Missing red lights in the dash
Missing a shifer knob
Missing a deck cover
Missing a gas tank
Missing a rectifier on the engine
Broken head light holder - needs replaced
Missing the battery hold downs
Missing the engine flywheel cover
Needs a new seat - Please show me some pics of a good replacement seat.
thats a quick going over...found more problems that i had originally saw when i bought it....this tranny and frame is caked in oil and grease and dirt...Lots of cleaning to do.
Michael Bullington
Got the engine removed !
rickv1957
Looks like your not wasting any time tearing into your 312,the fun part is putting them back together all cleaned up with some new parts!,Rick
Michael Bullington
Removed engine...This engine was abused! :omg:
rickv1957
Is the block OK?,Rick
Michael Bullington
Block looks to be okay...headed to the machine shop today to have the cylinder checked and honed :omg:
Duff
I'm not a motor man, so please bear with me here, but is that the connecting rod that's blown up and in pieces inside the block? :D
Duff :omg:
mavfreak
I would have a lot more checked that just the block and head. That crank doesn't look healthy and I would make sure the gears didn't get hurt in the explosion. All so check the oil pan to make sure nothing smacked it also. Just my opinion :omg:
Michael Bullington
Duff you hit the nail on the head!.....I should have mention I took the crank to the shop also...dropped them off this morning...hopefully they want take but one arm off of me :omg:
Hey I found my seat saftey switch is broken...the one that mounts into the pan...are these available aftermaket???
thanks
Michael
Michael Bullington
frame pics
rickv1957
Already painted frame,looks great! :omg: Rick
tranders
Looking forward to seeing how it turns out.
Keep us posted.
Michael Bullington
more updates
Duff
Michael, looking really good!
I believe seat switches are still available through Toro or parts houses. To the chagrin of some here (whose opinions I really do respect) I bypassed mine :D since I don't have any children and have a fair amount of experience operating tractors.
Duff :omg:
Michael Bullington
still waiting to hear from the engine shop! :omg: ..I think this will be my biggest hold up ...Im ready to mow
Michael Bullington
Updates on the Magnum...Well the engine shop had to punch the block .10 over to smooth it up ,,,also the crank had to be turned .10 ....so this is still a work in process...my engine had the Mahle piston and rod, I think i going to put this back in the engine although Brian Miller didnt think too highly of this piston
Quoto from millers site:
NOTE: I have some bad news concerning Mahle pistons! I was told by several sources that they're supposed to be made of tougher material than ordinary K-series pistons, but I found that they are not! I have personally taken apart several Magnum engines that was used in ordinary lawn mowing equipment, and I found that these pistons wear out sooner than the K-series pistons. So in my opinion, I think that Mahle pistons are junk and overpriced. You'll be much better off using an OEM Kohler K-series or an aftermarket import piston & rings. They last a lot longer than any Mahle piston that I've ever seen.
I would purchase the K series piston, but the cost difference doesnt weight out in my favor....Im already at $500 in this engine! :omg:
rick
Mahle makes pistons and cylinders for power saws that turn over 13,000 rpms, I wouldn't be afraid of one for a Kohler!
dgjks6
I know this is a month late, but I have and 89 312-8. We have owned since new. It still has original tires.
Armstrong on the rear
Carlisle on the front
