69DEZ 4 #1 Posted March 12, 2008 Thanks for the comments! I want to use the actuator to lift the plow. I was thinking I would have to mount something off both sides of the frame and have it come up like the piece of wood shows. But then I can't open the hood. Kevin suggested to mount it off the side. I guess I could do that. But would it lift straight? Any other thoughts???? Share this post Link to post Share on other sites
WheelHorse_of_course 99 #2 Posted March 13, 2008 I would mount it underneath, from the rear axle to the manual lift mechanism. This will give power lift for all your accessories. :thumbs: Share this post Link to post Share on other sites
kpinnc 11,894 #3 Posted March 13, 2008 Kevin suggested to mount it off the side. I guess I could do that. But would it lift straight? Any other thoughts???? Hey Dez, I think I've seen a similar setup somewhere with it mounted to one side. The top "bar" rotated across to both sides. It should be strong enough. However you do it, you're certainly off to a good start with your scoop. It looks very nice. Kevin Share this post Link to post Share on other sites
mrfixit82852 3 #4 Posted March 13, 2008 Thanks for the comments! I want to use the actuator to lift the plow. I was thinking I would have to mount something off both sides of the frame and have it come up like the piece of wood shows. But then I can't open the hood. Kevin suggested to mount it off the side. I guess I could do that. But would it lift straight? Any other thoughts???? You might be able to get some ideas from the photos I posted http://www.wheelhorseforum.com/index.php?showtopic=1689 Joe Share this post Link to post Share on other sites
69DEZ 4 #5 Posted March 13, 2008 Thanks for the ideas. Mr Fixit nice tractor!! :thumbs: Share this post Link to post Share on other sites
mrfixit82852 3 #6 Posted March 13, 2008 Just figure you might be able to use some of the ideas. Thanks Joe Share this post Link to post Share on other sites
baerpath 517 #7 Posted March 15, 2008 Just a thought, what if you went along the frame on both sides back behind the engine with 1/4 by 4 flat stock then angled up like your board from them? That would spread the stress out more on the frame. and not interfer with the hood :thumbs: Share this post Link to post Share on other sites
