algrc120man 0 #1 Posted April 5, 2010 does any one have an 8 speed trans to fit my c-120 it is currently a hydro that went wrong it is also a 1974 i have the pully and clutch pedal and disconect arm from a work horse chassis but i dont know if they will work on this machine. :omg: Share this post Link to post Share on other sites
rmaynard 15,595 #2 Posted April 5, 2010 Where are you located? Bob Share this post Link to post Share on other sites
Kelly 1,029 #3 Posted April 5, 2010 Let us know where you are, I have rolling frames with about everything you would need to make the swap. Share this post Link to post Share on other sites
algrc120man 0 #4 Posted April 5, 2010 Hey guys thanks for the responses im in midwestern ohio but going on a small weekend drive would not be out of the question so long as we are not in the field for planting yet then it be a while. :omg: Share this post Link to post Share on other sites
rickv1957 72 #5 Posted April 6, 2010 An 8 speed chasis would make an easy swap!!,Rick Share this post Link to post Share on other sites
Kelly 1,029 #7 Posted April 6, 2010 You will need the trans, clutch/brake parts, engine pulley, belt guard, new belt, your tractor should have the flip up fender, I think your tool box will bolt to the 8 speed and keep you fender set up, might want to swap out the dash tower, not sure how all that will work with a stick shift? You know what you need is a tractor that needs a engine :omg: Share this post Link to post Share on other sites
Horse Rancher 0 #8 Posted April 6, 2010 I do know you will need to swap the tower the hydro tower is about an inch taller if you get all the parts it's a straight forward bolt and go swap :omg: Share this post Link to post Share on other sites
algrc120man 0 #9 Posted April 8, 2010 thanks for all of your input guys sounds to be a bit of an undertaking maybe i should try to find a pump assy for it instead i think it is an eaton pump or a sunstrand not certain dont remember now. :omg: Share this post Link to post Share on other sites
