Pirate 0 #1 Posted April 2, 2010 I can't seem to find a picture of a WH tiller, to compare with the International one in the picture. just wondering if it could be adapted. I think in a picture of a WH tiller, it had a similiar large pulley. Also, it looks like at least a 48" tiller. I have a 414-8 WH Share this post Link to post Share on other sites
Kelly 1,030 #2 Posted April 2, 2010 Cubs use a right angle gear box to run those tillers, I have a tiller just like that one, I'm not sure it would turn the right way if direct drive like a WH? also the mounting is way differnt, where are you located? I have a couple WH tillers to sell. Share this post Link to post Share on other sites
Pirate 0 #3 Posted April 2, 2010 The guy has the gear box also. I haven't seen it yet. What does the gear box do ? Is the Int. a verticle shaft tractor? I'm in SW FL Share this post Link to post Share on other sites
Indy w h 5 #4 Posted April 2, 2010 The guy has the gear box also. I haven't seen it yet. What does the gear box do ? Is the Int. a verticle shaft tractor? I'm in SW FL The Cub Cadet in the picture is a horizontal Kohler engine. The Cub tiller will NOTfit a wheel horse. Indy Share this post Link to post Share on other sites
big mike 13 #5 Posted April 3, 2010 The PTO on the Cub is directly behind the grille and the crank runs parallel to the frame.The gear box bolts to the back side of the rear end and a loooong belt runs from the PTO to the gear box.The gear box has a second pulley that runs up to the tiller. Will not fit?.....untrue! Will it fit easily?......no. Share this post Link to post Share on other sites
