Irv
C-125 transmission
Irv
Putting together a C-125 Carcass I've had laying around and noticed today that when in gear in hi range I can slowly roll the tractor. When in low range, the trans locks up (normal). It seems like the shift lever may not be going over far enough into hi range. Motor is not in yet. Comments?? :omg: thanks
rmaynard
Had the same problem with a B-80 that had been sitting for years. Shifted through all the gears several times and it freed itself.
Bob
rickv1957
Does drive pulley spin at this time while pushing tractor? Rick
