The Toolman 22 #1 Posted March 24, 2010 My shifter was wobbbling around a lot, so I took it out of the tranny and it appears the pin holding the ball was broke an part gone. Look s like somebody tried to fix it before with a small real soft bolt for a pin. Now, I can make a new pin on the lathe for it, but how far does it go thru the ball an handle? All the way, or is it a little short so the bolt holding the shifter in can stick in the pin hole some? :omg: Share this post Link to post Share on other sites
stevasaurus 23,036 #2 Posted March 24, 2010 Could you tell us which tractor or (if you know) which transmission you have? They are not all the same. :omg: Share this post Link to post Share on other sites
rickv1957 73 #3 Posted March 24, 2010 Steve,Ron has a C101,Rick Share this post Link to post Share on other sites
stevasaurus 23,036 #4 Posted March 24, 2010 Dang...I see that now...senior moment. I was hoping it was a 3 speed uni-drive, because my shifter is laying on the bench. Too easy. :omg: Share this post Link to post Share on other sites
Save Old Iron 1,568 #5 Posted March 24, 2010 Could you tell us which tractor or (if you know) which transmission you have? They are not all the same. Still a valid question - he could be working on a different tractor ! Share this post Link to post Share on other sites
pfrederi 18,279 #6 Posted March 24, 2010 I am a little unclear on your problem. Are you talking about the dog point setscrew that goes through teh case and into the ring on the shifter or about one of the balls and springs that are inside the tranny?? Share this post Link to post Share on other sites
The Toolman 22 #7 Posted March 24, 2010 The stick itself and the 1/2 ball that it pivots on, that is on the shifter stick Share this post Link to post Share on other sites
rickv1957 73 #8 Posted March 24, 2010 Ron,that pin goes all the way through,the set screws starts in hole,just so shifter can move forward and backward,Rick Share this post Link to post Share on other sites
The Toolman 22 #9 Posted March 24, 2010 Ron,that pin goes all the way through,the set screw stops short of the pin hole,just stays in slot on ball so shifter can move forward and backward,Rick Please give me a buzz, some other info needed about it.. Thanx, Ron Share this post Link to post Share on other sites
oldandred 15 #10 Posted March 25, 2010 My shifter was wobbbling around a lot, so I took it out of the tranny and it appears the pin holding the ball was broke an part gone. Look s like somebody tried to fix it before with a small real soft bolt for a pin. Now, I can make a new pin on the lathe for it, but how far does it go thru the ball an handle? All the way, or is it a little short so the bolt holding the shifter in can stick in the pin hole some? the pin that goes though the ball as you call it and the stick goes all way and is even with the edges and doesnt stick out eigthor side or can be welded at the bottom and top take your pick Share this post Link to post Share on other sites
WheelHorse_of_course 99 #11 Posted March 29, 2010 The pin goes all the way through and is supposed to be a split pin. If the splint pin from your hardware store is to short just tap it in until it is centered in the ball. Best of luck :omg: Share this post Link to post Share on other sites
The Toolman 22 #12 Posted March 29, 2010 We got'er fixed an ready to roll..... My new WH buddy Larry fixed it for me. Found out I have a lot of WH fellers that lives around here. :omg: Share this post Link to post Share on other sites
WheelHorse_of_course 99 #13 Posted March 29, 2010 We got'er fixed an ready to roll..... My new WH buddy Larry fixed it for me. Found out I have a lot of WH fellers that lives around here. Just be careful, ok? There have been rustlers on this board that posed as friends! :omg: Share this post Link to post Share on other sites
rickv1957 73 #14 Posted March 29, 2010 Ron,glad you got it going,Larry is a great guy!,Rick Share this post Link to post Share on other sites
