Sparky-(Admin) 26,272 #1 Posted March 9, 2008 Anyone know the procedure for gittin some of the slop out of a "D"s steering. I remember reading about pullin a pin and tightening up a nut but cant remember where I read it, or where the pin and nut are. Mike......... Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted March 9, 2008 I can't give you the specifics, Mike -- other than don't over-tighten the adjuster cap. Here's a drawing to show the location on the end of the steering box: Share this post Link to post Share on other sites
Brrly1 1,146 #3 Posted March 9, 2008 Hello Terry I believe this turns counter-clock wise and not suppose to turn more than a half turn at a time. I was also told that while you are turning this nut that you are suppose to rotate the wheel back and forthin the area of the sloppy ness. This is what I was told so don't quote me maybe somebody else can also help out here. John Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #4 Posted March 9, 2008 I'm not too sure on which way to turn it, John -- but I would imagine it needs to be turned up in to the gearbox farther so it takes the play out of the bearings. Maybe it has L.H. threads ? You are definitely correct about wiggling the steering wheel back and forth too -- a guy at the alignment shop helped me do an old Ford truck box and told me to do that so the bearings wouldn't bind as I adjusted it. Share this post Link to post Share on other sites
kj4kicks 154 #5 Posted March 9, 2008 You probably won't be able to get all of the play out. if you make it snug in the "center" (where the most wear occurs), then the outer areas will be very tight. $.02 Share this post Link to post Share on other sites
Sparky-(Admin) 26,272 #6 Posted March 9, 2008 Well I did it. Pulled the pin and moved it (adjuster cap) less than a quarter turn and put the pin back.It didnt seem to want to go farther than that and I didnt want to overtighten it. Its better but still sloppy. While on my back under the "D" I noticed ALL the steering stuff is kinda loose or worn so I'll heat up the garage and tighten each piece this afternoon. Thanks for the replies guys.......Mike....... Share this post Link to post Share on other sites
bowtieguy 334 #7 Posted March 17, 2008 Did you turn it clockwise or CC?...got to tighten up my D-160 before grass starts growing in MO....I also noticed someone tried to ajust the "toe"...or is it "tow"..lol can I assume the both wheels should tow "in" just a little for it to steer correctly. Share this post Link to post Share on other sites
Sparky-(Admin) 26,272 #8 Posted March 17, 2008 I went clockwise. As far as toe-in I have no idea but I would think you would just adjust it to be straight and not pull either left or right. Any kind of toe-in would probably just tear up yer grass. I mean we're only goin 6mph, not like a car that hits high speeds so it just needs to be close. Mike........ Share this post Link to post Share on other sites
.5racer 15 #9 Posted March 18, 2008 Wheel Horse book 803646R1 states 1. Set steering gear on center by counting exact number of turns of the steering wheel . Stop wheel in the center of travel. 2. With the gear centered adjust the draglink to 18" center to center. 3. With the gear centered and the bell crank set as in step 2 adjust tie rods as required to set wheels straight ahead with a small amount of toe-in (1/16- 1/8 " ) 4. Turn steering all the way in both directions to see if the steering spindle arms are equally spaced from thier respective axle stops. 1 Share this post Link to post Share on other sites
Dburnsnavy 0 #10 Posted August 15, 2014 Anyone know where you can get steering box parts? Share this post Link to post Share on other sites
Trouty56 568 #11 Posted August 15, 2014 I think Jon Dear still has parts for the ross steering box....maybe.... Share this post Link to post Share on other sites
pacer 3,180 #12 Posted August 16, 2014 This Cub site has the parts - they fit the horse - almost at the bottom on the page. http://ihccw.com/steering.html Share this post Link to post Share on other sites
