rodco
C series Engine Mounts
rodco
I noticed that when I putt stress on the engine ( with loader PTO), the engine shakes in its mount quite a bit. Is this normal? Is is suppose to move on the rubber Mounts? Here is a photo of the mounts? Do they look ok or should they be replaced? Where would I get new ones?
ROB
billyban1
I put a new set in a C-165 last summer. I found a dealer that had 3 in stock and sold me the 3 at an old price list of $15 apiece. The forth one I had to have him order and it came with a $20 price tag. They are still available, but are very expensive. From the dealer, you're looking at $80 a set. I wouldn't consider a used set off e-bay, because they more than likely are soft and shot. The ones in your picture are basically gone.
The Toolman
Surely you can make do somehow with the rubbers that go on the threaded ends of shock absorbers.
