kthomas
rj 58 spindle gear
kthomas
Does anyone know where I may be able to get a spindle gear that is in the differential of my rj 58. I recently bid on one on ebay, but didn't know at the time how much I needed it.
DMK855
B)
As far as the gears, I would keep checking ebay!! Not sure which gear you are calling the spindle gear. If you are needing the brake shaft gear, I would recommend getting the differential assy. out of the same trans. !!
There were some gear sets on Ebay from Daves Tractor World recently.
kthomas
Inside the diferential there are four small gears top and bottom faceing opposite directions all similar, I need the shaft and gear for one of these. Thanks for the help.
clintonnut
I have what you are looking for. It is in decent shape and has the pin.
PM me if you are interested.
Charlie
rickv1957
Hello and B) Rick
kthomas
THANKS RICK I HAVE A LONG WAY TO GO TO CATCH UP TO YOU. B)
