CHARGER9AUTO 3 #1 Posted March 8, 2008 I should have the Delco - Remy Generator on my '63 953 but it does say the only tractor that has one is the 1045 . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,146 #2 Posted March 8, 2008 What's on yours now, Ben? It should have an oval tag riveted to the generator case. That will tell you the model number. It's the same S/G as the 1045, 1055, 1056, etc. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #3 Posted March 9, 2008 What's on yours now, Ben? It should have an oval tag riveted to the generator case. That will tell you the model number. It's the same S/G as the 1045, 1055, 1056, etc. Terry , The Generator's oval ID plate not on the Case anymore no where to be found I have the motor serial # and spec plate off the blower housing . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,146 #4 Posted March 9, 2008 Do you need the Delco - Remy numbers, Ben? I can get them off my 1056 if you just want to know what it is or need to order parts. The Kohler P/N is B-275703, but -- as you probably already know -- it's no longer available. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #5 Posted March 9, 2008 Do you need the Delco - Remy numbers, Ben? I can get them off my 1056 if you just want to know what it is or need to order parts. The Kohler P/N is B-275703, but -- as you probably already know -- it's no longer available. Terry in PA, The Wheel Horse Generator on my 953 has two oil filler holes one on each side . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,146 #6 Posted March 9, 2008 I have two of them, (that I can find) Ben. One is off of a 701 -- Model # 1101933 / Serial # 1A10 The other is off of a 753 -- Model #1101933 / Serial # 2016 They both have 6" cases and bearing oilers on both ends. My 1056 has a 7" case and the model # is 1101973 / serial # 6A 3. It does not have the oilers. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #7 Posted March 9, 2008 I have two of them, (that I can find) Ben. One is off of a 701 -- Model # 1101933 / Serial # 1A10 The other is off of a 753 -- Model #1101933 / Serial # 2016 They both have 6" cases and bearing oilers on both ends. My 1056 has a 7" case and the model # is 1101973 / serial # 6A 3. It does not have the oilers. Terry, I looked at ID plate on the Generator's Case it's a DELCO - REMY . Ben Share this post Link to post Share on other sites
CHARGER9AUTO 3 #8 Posted March 9, 2008 I have two of them, (that I can find) Ben. One is off of a 701 -- Model # 1101933 / Serial # 1A10 The other is off of a 753 -- Model #1101933 / Serial # 2016 They both have 6" cases and bearing oilers on both ends. My 1056 has a 7" case and the model # is 1101973 / serial # 6A 3. It does not have the oilers. Terry , The voltage regulator is wrong but it works it's not DELCO - REMY an off brand regulator . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,146 #9 Posted March 9, 2008 Terry, I looked at ID plate on the Generator's Case it's a DELCO - REMY . Ben Were you just trying to find out who made it, (they're all Delco - Remy) or do you need to work on it too? Older automobile starter/alternator repair shops can get parts and/or repair these units. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #10 Posted March 9, 2008 Were you just trying to find out who made it, (they're all Delco - Remy) or do you need to work on it too? Older automobile starter/alternator repair shops can get parts and/or repair these units. Terry, I found the Delco - Remy ID plate while wiring up the tractor no need to work on the Generator it works fine my 1045 has the same Generator except with no oil filler holes . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,146 #11 Posted March 9, 2008 Does the 953 S/G have a 6" long case? (just curious if it's a smaller one. ) The 1045 should be the same as my 1056 -- according to Kohler. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #12 Posted March 9, 2008 Does the 953 S/G have a 6" long case? (just curious if it's a smaller one. ) The 1045 should be the same as my 1056 -- according to Kohler. I do not know if my 953 has the 6" Generator Case . Ben Share this post Link to post Share on other sites
