Electro12WH 50 #1 Posted March 11, 2010 I have a 4 speed Unidrive that I rebuilt last year. I didn't use it much because it had shifting problems. It doesn't want to go into reverse without working it back and forth between R&1. It seems as if something is loose. I just took it apart to see what I may have left out. ??? I couldn't find anything wrong. The rails and forks seem fine. It has a new detent ball and springs. The shift lever mounts fine. Any ideas? Share this post Link to post Share on other sites
Coadster32 793 #2 Posted March 12, 2010 Did you install the reverse gear upside down? B) Share this post Link to post Share on other sites
Electro12WH 50 #3 Posted March 12, 2010 I'll have to check that tomorrow. Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted March 12, 2010 Did you install the reverse gear upside down? That was my first thought too. One end of the gear will have a "lead in" ground on the end of the teeth to help it engage with the other gear. Make sure that the lead in's face each other. Share this post Link to post Share on other sites
Electro12WH 50 #5 Posted March 12, 2010 The R-1 and 2-3 gears have the fork groove towards each other. The reverse idler has the bevel facing out away from the case. Share this post Link to post Share on other sites
stevasaurus 23,037 #6 Posted March 12, 2010 MikeRJ has an excellent detailed copy of the manual on his My Wheel Horse site. http://www.mywheelhorse.com/ Look for Mechanical Transmission Repair Manual :party: Share this post Link to post Share on other sites
MikesRJ 555 #7 Posted March 12, 2010 Here's the link: http://www.mywheelhorse.com/graphics/file/...1958_-_1982.pdf Share this post Link to post Share on other sites
