Steve in Mo
Help, what belt size???
Steve in Mo
I now have the small deck I wanted for my C101, went all the way to northern Ill to pick it up but it was worth it. I am bidding on a mule drive for it now. What I need is the belt size. the tractor is a C-101 as I have said and the deck is a md. # 78315 serial # 5900341. What is the correct belt and where do you suggest I purchase one. As always THANKS for all the help.
Old Dave
Steve:
Here is a link to the Toro website where you can download the manuals for that mower deck. Put it your model and s/n of the deck.https://lookup3.toro.com/request/sendreq.cfm
It says the OEM # for the belt is 110265.
markslawnmowerworld
that is the correct belt, its true measurements are 1/2"x141" if you choose to go for a after market belt....... B)
Steve in Mo
What can I say!!!!!!!! You guys are the best. Thanks again.
mcwh1950
steve First off deck model 78315 is a 37" side discharge .If you are using this deck on a c-101 and have front tire size 16x6.50x 8 rim ,you may have problem turning the c-101 to the right, because the deck will hit the front wheel. The 37" deck is mostly use with front tire size 15x6.00x6 The belt 110265 is a ha belt size 141 outside length x 0.5 width.
I would only buy this belt from a toro dealer .
