xring1 2 #1 Posted March 5, 2010 The 417A I bought seems to back up really slow but has plenty of power. The shifter hits the hydraulic engagement control and if i put more pressure on it it seems to be a little faster. I also notice that there in like a detent notch that the shifter lever might sit in....wonder if this might be the neutral position. Are there adjustments Share this post Link to post Share on other sites
rickv1957 72 #2 Posted March 6, 2010 There is some adjustments,also check for wear on linkage,Rick Share this post Link to post Share on other sites
xring1 2 #3 Posted March 6, 2010 There is some adjustments,also check for wear on linkage,Rick where can I find info on adjustments? Share this post Link to post Share on other sites
rickv1957 72 #4 Posted March 6, 2010 that info was posted a while back,you should be able to find it in this section if you look back a ways,Rick Share this post Link to post Share on other sites
