boatman
GT 14
boatman
:party:
Hi guys, I was wondering if it is posible to put the tack matic
hitch on mid frame and also the front tack matic off the front
of newer style tractors on the GT 14 so as to be able to use
a mower from c series or 400 series tractor? Also does anyone
know what part # key switch should be on 1969 GT 14? Tractor
starts and runs great but doesn't seem to be charging. I haven't
had a chance to diagnose yet. This engine has a funny looking
coil on it and will run without the battery. B)
rickv1957
Dont know if you can use the tach o matic on the GT14,that coil is part of the electronic ignition used late 60s to early 70s models,Rick
boatman
:party:
Thanks Rick, I thought maybe somebody might have
tried it. I need to get wiring diagram and correct ign switch
#. there are a couple wires that come off ign switch that
have been cut and I am not sure where they are suppose to go to.
Due to type of ign on engine I am assuming that the ign switch
has to ground out the coil like newer 312h command series eng.
B)
rickv1957
The electronic ignition switch does not ground coil,it powers coil and pickup,Rick
Brrly1
Boatman, you need to be very careful with that coil and pickup, if you get them wet, it can be very expensive to fix. Alot of people do away with them and switch over to points and regular coil. At which point they also have to switch the ignition switch to a different style of switch. I believe you can switch over to the tac-a-matic
setup. I don't know much about doing that but I am sure there are people here who have done that. Good Luck See Ya, Bye Burly :party:
B)
TT
Try again, Rick. B)
bowtieguy
I'll agree with John....be very cautious with that coil...it is expensive....when I got my 69 GT-14 several years ago, it had been sitting outsides for about 4 years cause the owner was in a nursing home and the kids would let anyone move anything until he died.....I bought it at his sale and switch was bad but I got the engine running after some minor stuff but it would not shut off...no problem, I'll just pull the spark plug wire off and kill the engine....never to start again....then I noticed the big caution decal on the engine shroud...DO NOT REMOVE SPARK PLUG WIRE WHILE ENGINE IS RUNNING.
100 bucks later and a new coil solved the problem..
Also FYI...if you order the 1969 manual from Toro you get SEVERAL manuals for many of the Wheel Horses that were manufactured in 1969...(GT-14 is included).
You can also get a free download op manual from Toro if you use model # 1-7441 but you will have to buy the parts manual.....my manual is out on "loan" right now so can't get the swithch # for you ...but will later if you don't find it.
Good tractor...you will like it.....ask John (Burley)....he's got one for every day of the week and a couple more for holidays~~~ B)
Brrly1
Frank, you got that right. Hey will I have your attention, are you going to the show this year? Talk to you soon See Ya, Bye Burly :party:
B)
bowtieguy
Sorry John...will miss your good company at the big show this year.....last year was probably my last one...unless gas gets real cheap! :party:
I did enjoy talking to ya at the show last year and hearing all about your GT's..
I checked model 1-7441 at partstree.com and they list the switch # as 8362 and will cost ya almost 50 bucks!!...(item # 232 on parts list)
John,....lets see....at that price you could sell all your GT switches and get RICH!! B)
Brrly1
Frank, there's a new one out in the garage already to go still in the package. The only thing is I have basically switched everything over to points and standard coil. I have a couple of the coils and pickups also but they will just hang out in case I switch one back to the electronic ignition. Its a bummer you won't be there, I am hoping that maybe Glenn will be there, he has a couple of the GT14's also. Ok, well we will talk to you soon See Ya, Bye Burly :party:
B)
Spelling correction
bitten
The orange wire from the rectifier ( center wire ) goes to the R post of ignition switch. From the B post there is a orange wire that goes to the ammeter and after that a red wire to the solenoid. That makes up the wiring for the charging system. The ignition switch does ground out the coil to shut engine off. The switch # is 8362 and can be found used on ebay a lot cheaper then a new one if you need one. I'm not completely sure on this but I don't think you want to run the engine without a battery hooked up.
As for the attach-a-matic going on the GT I think anything is possible but dont know what you would have to do.
Good Luck.
boatman
:party:
hello guys,
I was wondering if running tractor with out the battery would
hurt the rectifier or not. Previous owner jump started tractor
without the battery and had it running to load on my truck. I
put a battery in it when I got home but amp meter doesn't show
that it's charging.I haven't had time to ck wiring and see if
that is an issue. there is a red wire that is cut off coming from
ign switch tho. How hard is it to switch eng over to regular
coil and points set up? Thanks for all info. This is such a great place
to find out and share things. B)
