Iggy68
GT14
Iggy68
I am going to be looking at a GT14. It has not been running for almost 5 years.What kind of things should I look for with the hydrostat drive to check it out if the tractor isn't running. I wouldn't want to pay too much if it needs a bunch of work.
Sparky
Pull the dipstick first and see what the fluid looks like. Its either ATF which is red or 10w-30 motor oil. Make sure it looks clean with no signs of water. If the bottom of the dipstick is rusty it might of had water issues in the past. Then get under the tractor and check for leaks and cracks (or welding marks from past cracks B) ). Look at the axles where they leave the tranny case for leaks as well as any up/down play which might mean the axle bearings are bad.
Good luck.
Mike..........
rickv1957
Mark,another thing to check is the parking brake,pull up handle and see if brake sets and holds you from rocking tractor,Rick
bitten
Check to see if they released the tow valve if they had moved it. As you are looking under the seat it would be on the left side of the tractor.
Good Luck
Iggy68
Here is what I am looking at. 1972 model.
Don1977
It needs a new home all sad and neglected, buy it!!! :clap:B) :party:
rickv1957
Very well restorable or workable tractor!!,Rick
Iggy68
They are asking 500.00. I am going to offer 300.00. Is that fair? B)
Comes with the plow.
Sparky
More than fair for tractor with a motor you cant hear run.
Just my opinion.
Mike.........
