IthacaJeff 151 #1 Posted February 19, 2010 WH'ers: I'm in the market for a set of chains for my 416, if I recall correctly the tire size is 23-8.5-12. I'm looking locally (Craigslist etc.) because shipping on these suckers is a lot, and I'm seeing some ads that give a length and width rather than a tire size. I guess I could do a bit of geometry and figure out the diameter of my tires, but because the chain does not run around the outside diameter of the tire, I'd be guessing on what would actually fit. Any advice from the sages on converting chain length to tire size fit? Thanks, Jeff in Ithaca, NY Share this post Link to post Share on other sites
buckrancher 2,679 #2 Posted February 19, 2010 Hi Jeff have you tried over at Mazourek Farms?they may have a set Share this post Link to post Share on other sites
nylyon-(Admin) 7,258 #3 Posted February 19, 2010 I bought mine from an on-line vendor for I think something like $50 for my 416. Check your tire size, my 416 is 23-9.50-12, my 414 is 8.50's Share this post Link to post Share on other sites
Dresden Guy 24 #4 Posted February 19, 2010 Tractor Supply (at select stores - call to check) sells 23" X 8 Share this post Link to post Share on other sites
Dave M 0 #5 Posted February 20, 2010 I bought a set of 2-link chains from vulcantire.com after another forum member suggested this vendor. They were 52 bucks delivered, and included some tensioners. The ones at TSC were 4-link and were $58. My 416-8 is also a 23.00 x 9.50 x 12. The Vulcan chains look good and fit well. Fast delivery, too. Share this post Link to post Share on other sites
IthacaJeff 151 #6 Posted February 20, 2010 Hi guys, Thanks for the advice, but I'm not sure I made myself clear. I'm looking for used chains (i.e., cheap), but sometimes I see them advertised as the length of the chain, not the size of the tire they fit. For example, the ad might say the chains are 48" long and 12" wide. And the owner may not know what size tire they came off. Is there any way I can translate sizes like that into a 23 x 8.5 x 12 tire? Or do I need to bring a tire along?? Brian (BuckRancher): I'm hoping to get out to Mazourek Farms in the next couple of weeks and get all the goodies for the engine. (Work has a way of getting in my way.) I'm hoping you are still game! Jeff Ithaca, NY Share this post Link to post Share on other sites
