wheelhorsecravins 0 #1 Posted February 18, 2010 can anyone trll me where I can get axel seals, I have no manual for part #'s but old seals are two parts held in place bu a collar, thanks mike p s #'s on top of trans case behind the shifter is 3501 and # on raised block right saie of shifter is E26D N Share this post Link to post Share on other sites
VinsRJ 721 #2 Posted February 18, 2010 Original axel seal which fits in side the axel tube is: CR Services Seal Part # 9815 / HM14 Axel seal which crimps over the axel tube is: SKF Seal Parts # 9835 / HM14 R In-Put and Brake Shaft seals are: National Seal Part # 471643 or Victor Seal Part # 65140 I'll have some of these seals in stock shortly. Share this post Link to post Share on other sites
MikesRJ 552 #3 Posted February 18, 2010 I don't know which RJ you're working on so here's all three manuals: RJ-25/35: http://www.mywheelhorse.com/graphics/file/...vice-Manual.pdf RJ-58: http://www.mywheelhorse.com/graphics/file/...M&IPL_RJ-58.pdf I would suggest you go to a Toro Dealership and buy the seals, or you can buy them direct from the Toro website. The part numbers you need will be in one of the manuals above. Share this post Link to post Share on other sites
DMK855 15 #4 Posted February 18, 2010 Toro axle seals - 83-2840 Toro Input/Brake shaft seal - 83-2830 They are still available from your Toro Dealer!! Share this post Link to post Share on other sites
