6wheeler
Hydraulics inquiry
6wheeler
B) I am wondering if anyone knows, was there ever hydraulics on a C-165? I have had this idea to put some on mine. I think I can fabricate a pump mount easy enough, but figuring out where to mount the cylinder might be tougher. Any thoughts? thanks Pat
baerpath
try looking on Toro's sit and use 01-16ke01 for a C165 hydro, or 01-17ke01 for a C175 hydro
6wheeler
Thanks, I looked but all it shows is the parts breakdown. I need to see how a cylinder lays in the frame. I will have to try to find a picture of one, or maybe a tractor for parts. Thanks Pat
rickv1957
A C165 hydro had optional hyd lift,Rick
tophatbufflo
On the older ones they mounted the cylinderfront to the floor board mount and the rear to the rocker shaft. 70 era tractors
6wheeler
Rick, I thought there was something like that. I have never seen one. I have a friend with a c-165 auto but no hyd. either. Would you know how the cylinder mounts. The reason I am asking, I may be able to do this for about $150. If I can make it work, I may be able to get a 3 point setup to work. My parts would be after market, not WH. Before the lynch mob saddles up and heads north, comperable parts , If I could get them, would be alot more. I have a couple of electric lifts I may try also. Thanks for the help Pat
