73-18 automatic
D160 pump shaft stripped
73-18 automatic
I was pushing snow today and I heard a grinding sound and was not able to move forwards or reverse found out that pump shaft is stripped and I am trying to remember where to get one any help would be good thanks
Doug
rickv1957
You will have to replace pump shaft and yoke if you can find the parts,I have seen a couple of Ds over the years that had that problem and yoke and shaft were drilled through and had bolt and nut installed,crude fix but worked,Rick
73-18 automatic
Cool thanks Rick for the info
Doug B)
d180man
Hi yes we have seen that too good luck on it ! some time you can find a good part one on ebay ! B) :party:
Horse Rancher
what about machining it down and milling in a keyway then
you could sleeve the drive hub and machine a keyway in that also B)
73-18 automatic
Horse Rancher that sounds like a good idea just wonder how well it would hold up and need to find a machine shop thanks
Doug
Horse Rancher
Your in luck as my father and i have a machine shop in my
garage we have a mill a new lathe a bandsaw mig tig and stick
welders works wonders for fixing these older tractors if you
would be interested in a repair either give us a call at
(231)853-6571 or (231)853-5359 or shoot us an e-mail
thanks Jim & Dan :party: B)
73-18 automatic
Dag gone this D 160 man it stripped both the shaft and the coupler here are some pic
rickv1957
Have only seen a very few stripped over the years,really they have held up good for 30+ years old B) Rick :party:
73-18 automatic
Yes they have I was able to drill coupler but not able to drill shaft so I decided to replace pump with a different one hopefully it will work just as good
and it in the tractor have not tested it yet
73-18 automatic
Hopefully this pump will be as good or better but it is older because it is a 90-1137 the one that came out was a 90-1173
rickv1957
Splines look geat,good luck with it!,Rick
d180man
Hi good luck on the pump ! B) :party:
dgoyette
Boy you couldn't ask for nicer splines than on that new pump. Did the coupler come with it? Having the mating coupler that kept it in that condition would be nice. Obviously was tight and a great match, unless that pump has been rebuilt with a new spline which may be very likely for an older pump.
bitten
I know that things wear out, but what would cause this?
73-18 automatic
UPDATE It's ALIVE wow this pump seams yo be in great shape I ran the tractor for about an hour and it had plenty of power dgoyette as far as the coupler no I do not have the one that matches the pump but I do have a newer one that is in good shape
and to answer bitten's question I have been told that this was a common problem with Onan power D's but I guess over time the vibration and forward to backward does not help either thanks Doug
d180man
HI it was just not the onan engines have looked at over 5 kohlers that did the same thing ! but good to hear you got it up and running ! B) :party:
73-18 automatic
Thanks d180man I had heard that it was real common on the Onan power D's but I guess after 30+ years of use/abuse anything will wear out I will give it the ultimate test today I have some snow to push thanks again
Doug
rickv1957
Doug,Glad to see your up and running! B) Rick
73-18 automatic
thanks rick I pushed some snow today and so far so good seemed to have plenty of power even after about 2 hours of use thanks again
Doug :party:
d180man
Hi that great ! news ! B) :party:
dgoyette
That's awesome Doug. Especially glad to hear it because I know there are folks depending on your and your D for snow removal!
I got to check out the splines on mine today. Just removed the engine bolts and moved it a bit forward and yes the coupler just spins on the pump splines. Completely striped I would guess. Pump splines look pretty bad too. I took a few pics but they came out so bad I am not even going to upload. I guess the pump is coming off!
dgoyette
Question for you guys on the coupler. I have seen two different types in regards to how the iron coupler is oriented on the rubber coupler. One is the way Doug's is (mine is as well) and this one.
See how the coupler appears to be reversed? My WH part's diagram also shows it oriented this way. Were there some models that had different couplers? Like maybe the D-160 used a different one?
Doug's and my coupler
defed
is the pump shaft hardened? if not, i would probably try to remove the coupling, drill it for a pin, reinstall it and use it as a guide to drill the shaft. would save alot of work removing the pump.
also, any time you move the engine forward and then move it back to engage the pump, it says in the repair manual to use a timing light on the coupler to make sure it is aligned squarely. if the engine is crooked, it still might engage the pump but would probably add stress to various parts.
d180man
Hi Darren i have seen 1 or 2 like that some one told me if you flip iron coupler you get more splines coverd ? they say there is around 1/2 to 3/4" space if you put it on the right way and if you flip it it will go all the to the pump ! but good luck on fixing it ! just clean it good before you take it off ! B) :party:
