Horse Fanatic
drive pulley diameter
Horse Fanatic
Anyone know if the engine drive pulley was the same or different diameter for a Sustrand and Eaton trans?
Thanks in advance,
Glenn
rickv1957
They are the same,Rick
Sparky
I'm pretty sure that they were both 5" pulleys.
Mike.........
Horse Fanatic
I was asking because there was one on ebay I just bought that the seller says is 5 1/4" diameter. Thought maybe Sustrands used a larger one. 1/4" wouldn't make much difference anyway.
Thanks for the replys!
Glenn
W9JAB
When it comes to pulleys (sheaves) it depends on the belt size it can handle, if the sheave is for an A, 4L, 5L, & B belts the O.D. of 5.25 will be 4.50 for 4L (A & AX) and 4.90 for 5L (B & BX) pitch Dia. or the actual diameter the belt will travel. This is only important when calculating speed and your right it will not make much difference, unless you have a clearance issue.
You may want to read this post,
http://www.wheelhorseforum.com/index.php?...topic=12917&hl=
:thumbs:
