jdwheelhorse
Starting B80 Restoration
jdwheelhorse
Your making a great start!,Rick
Thanks! Will keep progress posted :thumbs:
jdwheelhorse
Progress for the day: 6 parts primered and ready for paint. Hood still needs welded, might get done tomorrow. By the weekend, tractor will be mostly red... B)
jdwheelhorse
Hello, it's been a while since ive updated my progress but i have gotten alot done since then. :omg:
Here is the Hood and Crank case sheet metal:
Starting the break down...
Frame:
Transmission:
Rolling Chassis:
Up next is the body/subframe/dash tower, rear fender, side steps and other small parts. Motor break down and cleaning/painting is last. Opened trans. and all looks good, minimal wear, fresh oil and new hitch pin. Replacing all/most hardware with grade 8 nuts/bolts.
rmaynard
Nice to see progress being made. :omg:
Bob
jdwheelhorse
yes! im hoping to get done soon. it's looking real good so far.
what is the easiest way of getting the tire off the rim? flat screw driver after deflation?
rmaynard
Are you still liking the Krylon Cherry Red?
Bob
MikesRJ
mods please delete ... wrong thread (duh).
Roger from southern Iowa
You're making lots of right decisions on this job. :omg:
Keep up the good work and keep the pics coming.
jdwheelhorse
what?
jdwheelhorse
Bob
yes i love it. its cheap and it looks good and dries within 20 minutes, and over a period of time it's pretty durable.
d200
I love B-80's. I also have a restored one. Still need to figure out a new air cleaner design. Had to replace blown kohler 8 hp for a new 10 hp briggs pressurized. Good luck with the resto. :omg:
rickv1957
Looks like your B80 is coming right along,nice work!!,Rick
jdwheelhorse
I'm stuck at the moment because i cannot get the steering wheel off...is there anyway to take the pinnion gear off the end of the shaft and take the shaft collar off from under the dash? and then just pull the whole shaft out? Any help would be appreciated!
thanks.
Wheelbearing
thanks.
Heres how I did it. puller from harbor freight.
I did have to drill a 1/2 hole through the plastic till I hit the top of the steering shaft. but that under the cover anyways.
jdwheelhorse
well, isnt there a pin that goes through the bottom of the steering wheel and through the shaft? i couldn't get it out, and i couldnt even get the shaft collar off thats under the dash. I guess im just gonna paint it with it there and work around it. :omg:
thanks.
jdwheelhorse
Subframe is done, gastank tray area is done, putting engine on tomorrow, and should have a running tractor. Gonna start rewire soon and also might be buying another horse that needs rewired and carb.
WIll post pictures later. :omg:
Duff
thanks.
JD, those roll pins are a real b**ch, and they used them in a few places on the tractors. I invested in a set of roll pin punches (not that expensive) and found with PB Blaster, some heat and patience, I was able to get them out. That shaft collar, on the other hand - I had to cut them off my tractors with a Dremel tool. But replacements are available for a variety of sources and not that bad cost-wise. On the tractor I'm finishing up now I got a stainless shaft collar in case I ever need to take things apart again.
Duff :D
rmaynard
The roll pin cannot be heated without seriously damaging the plastic steering wheel. If PB Blaster and a pin punch won't get it out, you might try drilling it out. Then you can use a wheel puller as shown in 'wheelbearings' post to get the steering wheel off the shaft.
Bob
jdwheelhorse
Ok, Just worked around the steering wheel and this is progress so far:
dropping the engine in tomorrow and painting rear fender, should have a drivable tractor!
MikesRJ
Not quite true!
There is a product named Hot-Stop ( http://www.mechanicstimesavers.com/shop/intro/hotstop.asp ) which when sprayed on the spokes of say an RJ-58 it will not allow the heat to migrate out to the handle. I have personally cherried the center of now three wheels and have not damaged the hand grip at all. In fact the grip did not even get warm while the center hub was literally glowing red.
This situation I suspect is a bit different from an RJ, but the product could be useful in this one as well. I don't have one of these machines, so I wouldn't know from Adam.
EDIT: I now understand how the wheel is assembled and don't think even this product would help under the circumstances.
jdwheelhorse
Got the motor dropped in yesterday and ran into a little problem...seems like i need a new belt because the clutch pully is not stopping the belt all the way. So what is the best cheap brand of belts to replace ours? or do i need to stick with original?
MikesRJ
http://www.mywheelhorse.com/graphics/image/10-8/R-002.JPG
^^^^^ That is your tractor, isn't it? :omg:
Hence the reason for the edit. I realized it after the original post when I actually got out of my chair and looked.
rmaynard
Not quite true!
Mike,
This is the pin that he is talking about. You can't heat this pin without damaging the plastic.
Bob
jdwheelhorse
Painting of large parts is complete. Will post pictures later today, also wiring headlight and two tails tonight. Decided to go with a tail light on each side of the fender and put a decal in between because there are a bunch of holes i did not get filled.
