rmaynard
Can Anyone ID This Dash Panel?
rmaynard
In my search for the elusive NOS B-100 Dash Panel, I came across this one.
Does anyone know exactly which model this is from?
I have highlighted the embossing with chalk to make it more visible. Otherwise, this one appears to have been all black with no highlights.
Thanks.
Bob
stevebo
Not positive but looks like an older c series like c100/120
rmaynard
I'm sure RickV is out in the barn right now comparing the picture to one of his 47 horses and will have the definitive answer momentarily. :thumbs:
Bob
Bow_Extreme
That dash panel was used on the "B" series tractors and maybe the "C" series as well.
rmaynard
It is different than my B-100 as shown below:
Bob
Sparky
I realize that your looking for a NOS dash Bob but whats wrong with yours? Looks good and doesnt seem to be cracked in the picture :thumbs: .
The other one you showed is definitly off a Kohler powered machine as a "C" series with a Briggs did not have a slot for the choke.
Mike..........
mcwh1950
bob i got this same dash on a 77- b-80 1978 c-81 and a 1979 c-121
if you got this dash on your 1977 b-100 what is the elec clutch use for .
after looking again the b-80 dash is differ ,it doesn't have the hole drill out for a light switch.
rmaynard
Mike..........
Sparky,
The B-100 dash in the picture does not show that it is warped. Also, the embossing has been silver-foil leafed. I don't know how well it will hold up.
Thanks for the info though.
Duke,
Thanks for that info
Bob
TT
Guaranteed-original, one-owner 1976 B-80 dash with both toggle switch holes plugged with the correct plastic plugs:
I can't remember if my 1975 B-80 had the electric clutch switch hole or not. :thumbs:
HankB
Looks like the same dash may have been used on the A-80 as well.
Sparky
Whats that extra thing just to the right of the choke lever? Looks like a push button :thumbs: ?
Mike..........
TT
Whats that extra thing just to the right of the choke lever? Looks like a push button........
Nitrous? :thumbs:
Bow_Extreme
I also believe these dash panels were interchanged on some of the very same models. I have a dash with holes for all options that came off a B-100 and also pulled a matching one off a B-80. They could have been swapped out at one time or another as I wasn't the original owner nor did I acquire them from the original owner.
buckeyebill440
Same as my C121....
bork
Nitrous? :lol:
:thumbs::banghead::WRS: :wwp:
rmaynard
Mike..........
That is a cigarette lighter.
Bob
rmaynard
All of the ones that you guys have shown pictures of are different. The one I am asking about has no cigarette lighter hole, no electric clutch hole, and no rabbit or turtle symbols.
My B-100 dash does have the holes for the lights and clutch, but they are plugged like in the picture that "TT" attached.
Bob
Daddy Don
Same dash as my 1979 C111
HankB
Nitrous? :banghead:
You wouldn't believe how fast....
:thumbs:
No, just a push button on/off switch. Judging by the look of the other dash panels, I don;t think it is OE. Nothing connects to it and there is nothing on the tractor to power with it.
rickv1957
Bob,looks like a late 70s dash for sure,Rick
rickv1957
Bob,your original dash looks good,cant see how it is warped in picture but you can use a heat gun and maybe straighten out,has worked great for me,also all dash panels were highlighted when new,Rick
rustynut
im sayin its a c-120
rmaynard
Rick,
I have tried heating it and putting a reverse stress on it, but it keeps going back to the same old bow. I know it doesn't look all that bad, but because of the location of the bow, it is going to catch dirt and water. I guess I could use some glue and glue it to the back plate.
I'm still thinking hard about the NOS panel that you have.
Bob
mnWHfan
That dash was used on the 1978 and 1979 C-series tractors. I have that same one on each of my C161's.
bitten
I have thought about putting it in a oven on a flat surface. Anyone try this?
