aaredneck
I don't know what model Wheel Horse I have
aaredneck
i need some help i have a wheelhorse tractor but i cant find my model i look everywhere but cant ever find my model tractor all the parts are origonal except for the engine i put a 25 horse briggs and straton on it i have the front end and seat but right now its just not together the tractor runs very nice its a 3 speed but id love to no the model wheelhorse ??????? can anyone help me out
pbradley68
Do you have any photos? You'll get a pretty quick answer from lots of people here if they can see it. If not you can dig through the picture gallery to see what matches up with yours. http://www.wheelhorseforum.com/index.php?showforum=29
KB9LOR
Check on the lower dash tower," right below the dash that holds the choke and throttle cable"
Indy w h
Here is the pics
let's help out our newest member guys!!!!
Indy
evanloock
Either a 704, 604 or 654.
rickv1957
hello and :thumbs: Rick
TT
:thumbs:
Your "25hp" engine is probably only around 9 to 14. :banghead:
bell
looks (possibly) like a 603... Or, what's left of one.
Is there a plate bolted to a square hole where the ignition switch is mounted?
evanloock
Doubt it's a 603. Don't see the square cutout in the hoodstand. If it is a 603 it also has the wrong footrests, front axle, steering wheel and someone has added a Dial-A-Height bracket in place of the old lift lock bracket.
aaredneck
Does anybody have any info on a 603 im tryin to restore the hole thing to make it origonal and i figured it could be easyer if i had a parts manual? or just something that lists all the parts in a parts breakdown
Kelly
First are you sure it's a 603? the pictures are gone now, can you put up better pictures of the dash tower, right in front of the seat, the front axle from the front, then we can have a better idea what it is, if it's a 603 you have you work cut out finding all the missing parts, many are 603 only.
Kelly
I have a copy of the IPL I can scan and send to you of the 603
Indy w h
That's a bummer, I just deleted all his pics off my iPhone
last night!!! :thumbs:
Indy
aaredneck
i can email them to u again indy i cant post them my camera wont lett me
Indy w h
Pics again
sorry, thought I moved the pics. Ended up deleting them :thumbs:
Indy
linen beige
That is NOT a 603.
TT
That is NOT a 603.
Why isn't it? :thumbs:
linen beige
That is NOT a 603.
It is possible that it started out life as one, but not very likely.
As Eric said...
Wrong steering wheel. The 603 used the half moon style.
Wrong hood stand/console. The 603 had the engine controls mounted in the console and there is no hole for them in this one.
Wrong foot rests. The 603 used ones similar to the '61 models.
Wrong lift handle stop set up.
Wrong front axle.
I can't see the brake area well enough in these pics to tell if that area looks like it could be a 603.
Are there some details that make you think it is a 603?
d180man
Hi :WRS::thumbs: :banghead:
TT
I see a flat axle mounting plate on the front of the frame, the '61/'61 front axle, and the strap steel tie rod with the single drag link in the pictures I'm looking at on my computer. :thumbs:
All the rest of that stuff like hoodstand holes, steering wheel, and footrests could have been modified or changed in the last 45+ years.
Perhaps the owner can get some better pictures. :banghead:
aaredneck
that is the way i got it from my buddy and didnt think much of what kind of tractor it was untill my other frend came to look at it and said its a wheel horse and i looked into all the information im trying to make it back to the way it should be there is a spot for the controls theres just a plate bolted over it
bell
I'm sticking with 603... (heavily modified over the years, but nevertheless...)
Would like to see some better pics tho.
CasualObserver
Seems to me that it will be pretty easy to put the "is it a 603" question to rest if you can find one piece of information. Is the hood stand welded to the frame? (I can't tell definitively from the blur of the picture) The 603 is the ONLY tractor that used the 2878 Frame that had the hood stand welded in place as one unit. All the others had separate part numbers for the hood stand and frame and the two parts were bolted together.
Here's what it will look like.
no bolts inside either.
aaredneck
yes ill get some betta pics but my wheelhorse is stuck behind my johndeer 4020 so im not sure when ill have time to pull it out but yes the hoos stand is welded to the frame
Indy w h
More pics
