Countdown To Christmas!
hummod
753 transmission
hummod
I have the 753 that I am working on running good now. The head was removed
and replaced using a torn head gasket. A new head gasket was installed to fix it.
I seem to have a transmission problem now. First and reverse work good but
second and third seem to slip. Third is worse than second and it happens when
going up a slight grade. Both hubs have been checked and are tight. I think I
need to open up the transmission and see what's going on inside. The problem is
I don't know where to begin. Any suggestions on what to look for or how to get
started would be helpful.
Thanks, Larry
TT
Go to the illustrated parts list of your transmission and find the #17 "gear-input drive" (P/N 3522) and the #21 "high & intermediate gear" (P/N 3523).
There's a 98% chance you'll need to replace both pieces - and good ones are getting tougher to find.
Coadster32
Terry is right on this one. The only other thing it could be would be a missing ball detent. However, that most likely won't fix third gear. If you want to see pics on the inside of the case, goto my 551 restore thread form approx. 1 year ago. Good luck. Either way, you're taking it apart.
hummod
Thanks for the replys. The only thing I can add is that the shifter doesn't
seem to be going all the way left into third. The shifter is quite far right while
in second but third seems to hang up before it gets all the way over. I plan to
open it up as soon as it warms up a little. I got the link to the transmission
manual, that should come in handy.
Thanks again, Larry
TT
Larry.....
Can you twist (spin or rotate) the shifter around? Does it have any up & down motion?
Can you pull it out and check the condition of the roll pin holding the pivot "ball" to the shift lever?
Getting the shifter retaining setscrew out can be accomplished on these without cutting access holes (I've seen a few :banghead: ) if you cut a hex key ("Allen wrench") off very short on the short end. I'm having brain freeze right now, but I believe you'll need a 1/8" key. :thumbs:
hummod
The previous owner had snapped the shifter off and I replaced it with one off
my commando 8 then I found another in the parts box. The shifter is tight with only a small amount of side to side motion. When I first got it the shifter would barley move between second and third. As I kept working it and after two full flushes with 10-30 wt motor oil and one with kerosene (to get water out) it moves real easy. It just doesn't seem to be going into third far enough in my opinion to reach a fully engaged position. The shifter feels like it is locking in all other gears but third can very easily be knocked back to neutral. Third gear is engaged and is moving the tractor on flat ground but starts to balk and jerk when going up an incline. Almost as if a gear is intermittinly slipping on a shaft that it should be locked to.
Larry
hummod
I will let you know what I find as soon as I get it apart. I have been lucky so far
in that I have not needed to work on a transaxle yet. The two parts that were
mentioned (3522 ans 3523) look like they are used in the Commando 8 too. The
four speed transaxles must be very similar through most of the middle 60's.
Larry
sscotsman
Hi Larry,
sorry, I dont know anything about your transmission issue,
but I just wanted to say..I was born in Sayre and grew up in Waverly! :banghead:
all my family is still in the valley..(im the first Lawrence to leave Waverly in 150 years..seriously..) if you know any Kremers, Canavans or Taladas,
those are my cousins!
nice to meet someone from The Valley here! :thumbs:
Scot
hummod
I grew up in Chemung, NY and went to Waverly High School class of
1978. I currently reside in South Waverly. The only Taladas I knew of
lived a few miles from us in Chemung. It's always good to hear from
any former or current residents of "The Valley"
Larry
sscotsman
Larry,
im WHS class of '87 myself..
my Dad was WHS class of '59,
and my Grandfather WHS class of '29!
nice to "meet" you. :thumbs:
(my first Girlfriend was from Chemung! :banghead:
small world..
Scot
TT
Wow.... You two are both on a Wheel Horse forum talking about that area and you never once mentioned HORSEHEADS?! :banghead:
:thumbs:
hummod
Horseheads is a strange name for a village. I know there is a story of
how it got it's name. I think the Indians referred to the area as "The Valley of
the Horses Heads". I will need to look into it further. We usually just pass through
there on our way to the lake or when going to the Arnot Mall. I do see a few
Wheel Horses and their owners around there. Not many parked in the hedge rows, most still running strong.
Larry
TT
I delivered a few loads of brass to Thomas & Betts out in the industrial park at Horseheads. I traveled RT14 all the way up through PA and always watched for tractors.
I do remember one (I think it was a GT-14) sitting across from the Radio Shack in Columbia Cross Roads, and a few at the little mower repair shop in Gillette. :thumbs:
It's been a while, so they're probably all gone.
~ETC~
>_> taladas huh? :thumbs:
i went out with a chick with that last name ......lool got any relatives in michigan?
i kno the grandma moved back to where she grew up.. i think it was Pennsylvania but not 100% sure
:banghead:
