glenn27
Brinly 8" plow
glenn27
I believe its a brinly, but not positive.
Looks just like the one I have that came w/ a Cub--mine is 10"--but same I.D.
You can still order parts and a mnaual from Brinley on-line...I'll post the site (I have @ home) later on if'n you need it--
Let me now....... :thumbs:
combatmp29r
That would be great Glenn. I still need to drag it out and measure it. it may be a 10" I sold a 12 last year and it dwarfed this thing so I assumed it was an 8. Looking at 8s now though I think it may be a 10. Either way the V8s pull it without issue.
Kelly
With the attachment pin that long you don't need a colter on there.
combatmp29r
You like that Kelly? It was the only pin I had when I set up the clevis hitch. Well the only one I could find. Its cut down to size and drilled for an clip now :D
I measured it tonight. Its a 7 1/4" plow :thumbs: I'm guessing that means its an 8" :thumbs: I measured the 4 bottom sitting at the neighbors too to make sure I was measuring right. Its 16" on the money so mine must be pretty worn or something.
