TT-(Moderator) 1,131 #26 Posted March 3, 2008 Cheers guys Im quite chuffed at winning it for only Share this post Link to post Share on other sites
Stigian 1,234 #27 Posted March 5, 2008 Picking up the engine on saturday, fingers crossed it will be good enough to help my Raider on the road to recovery :thumbs: Share this post Link to post Share on other sites
wesley 32 #28 Posted March 6, 2008 WES is looking through lans shop window to se if there may be a spare 10 hp engine block going in case he needs it, lan wont miss it . lan with ref to your ujs and drive shafts , have got a pair ready to go for you , will bring them with me on the 16th,dont want money will trade baccy or swap etc , l did some lathe work for them , soon as l saw them , l thought , theres a home waiting for them , and l think they wil be just what you need for the 4x4, dam l love it when a plans comes together. wes Share this post Link to post Share on other sites
Stigian 1,234 #29 Posted March 6, 2008 Cheers for sorting the UJ's for me Wes Im always up for a bit of trading Im not quite sure on the plans for the 10hp block It would be nice to rebuild it and put it back in the Raider, but i need to pull it apart to find out how bad the bore really is :thumbs: Share this post Link to post Share on other sites
Stigian 1,234 #30 Posted March 8, 2008 Afternoon all, My Wife drove me to pick up the Ebay engine this morning (thanks Wifey if your reading this ), and now ive had the time to have a closer look at the heavy blue lump im a very happy camper In a change from the normal ebay luck the engine is in much better condition than it looked on the ad Heres why. The wire mesh that keeps fingers out the cooling fan is missing But so are the very hard to get out cross head screws, and the threads are good One less job Will you look at that.... its had a plastic replacement fuel pump Not original, but a bit newer Time to pull it apart A light dusting of surface rust around the valves, but the valves and seats are in good condition. Im really starting to like this engine at this point Someone in the past had taken time to de-coke the head, just a slight bit off "ally fur" where the spark plug had been left out.. Oh and a spider skin The bore is very clean, a slight bit of movement on the piston but way, way better than the current Raider engine Im still not sure quite which engine it is It has a 5 cast in the block about here. And 45 736 02 behind the flywheel about here The sump pan is wrong as you guys pointed out it needs to come off anyway to see what the guts of the motor are like. Have i missed anything Oh yes, bore size 86mm with a quick measure up.... Hmmmm 3.375" is a 14hp engine, 3.375" is 85.725mm Yippie its a 14hp :P Share this post Link to post Share on other sites
Greg B. 1 #31 Posted March 8, 2008 :thumbs: Congratulations, Ian So far it looks like you got yourself a winner. I hope the bottom end is as good. Greg B. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #32 Posted March 8, 2008 Have i missed anything Oh yes, bore size 86mm with a quick measure up.... Hmmmm 3.375" is a 14hp engine, 3.375" is 85.725mm Yippie its a 14hp Ian..... I screwed up! 3.375" is a K-301 12hp and 3.500" is a K-321 14hp. (3.250" is actually a 10hp) I'm sorry that I had them wrong, but you still got a tremendous deal on your engine! :D Share this post Link to post Share on other sites
Stigian 1,234 #33 Posted March 8, 2008 Ian..... I screwed up! Lol, dont worry about it Terry, we all do it sometimes So if ive got my ing right, if the k241 sump pan fits the k301 then all is cool If not i need to make an adapter plate to mount the engine in the Raider and all will be cool 14hp would of been nice, but 12 is better than 10 :P Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #34 Posted March 8, 2008 So if ive got my ing right, if the k241 sump pan fits the k301 then all is cool 14hp would of been nice, but 12 is better than 10 The oil pan is a direct bolt-on, Ian. I can't see the side of the block where the dipstick should fasten (for the Raider), but I know you'll be able to drill the 4 holes if you need to. 2 cubic inches smaller won't hurt as much as 6 cubic inches bigger will help. A 12hp Kohler is a very good engine! :D Share this post Link to post Share on other sites
Stigian 1,234 #35 Posted March 8, 2008 The dipstick on the Raider is a big square headed that screws into the top of the block on the starter motor side. The k301 has the same looking thing but with a sunken square head. Should be a straight swap 12hp Kohlers are great workhorses, my 312-8 pulls like a train :D Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #36 Posted March 8, 2008 I wasn't sure if your Raider had the bolt-on dipstick..... You have it made then (that's probably just a pipe plug in the "new" engine.) :thumbs: Share this post Link to post Share on other sites
wesley 32 #37 Posted March 8, 2008 Well done lan am pleased for you, am looking forward to seing the engine next sunday, if the crank etc is ok , whitch l think will be , why not treat it to a set of rings, if you want to do that l will bring my honeing tool with me and do it next sunday for you, let me no. wes Share this post Link to post Share on other sites
curly 0 #38 Posted March 9, 2008 You might try www.kohlerplus.com and enter as a guest. Service manuals etc a great help to me. Curly in KY Share this post Link to post Share on other sites
Stigian 1,234 #39 Posted March 9, 2008 Cheers Curly if ive not said so already I have been thinking of a new set of rings in it Wes, id better see if i can get them here for next sunday :P Share this post Link to post Share on other sites
Stigian 1,234 #40 Posted March 11, 2008 Its official... My new engine is a 12hp paperweight <_< I dropped the sump pan off yesterday, and at first the guts of the lump looked ok. Until i checked out the sump pan that had been sitting draining away. HHmm... Me thinks its not had an oil change in a while Time to check for any play... it didnt look good. Wiggling Vid Slightly scored may be an understatement The crankshaft has score marks big enough to get bus wheels stuck in. Sorry its not the best of pic's but all the close-ups came out blurred. The piston has seen better days as well If the crank is savable with a regrind then it might be worth ordering a new piston and rod and rebuilding it. If the crank is totaled then at least ive got a fuel pump out of the deal :P Share this post Link to post Share on other sites
Rollerman 290 #41 Posted March 11, 2008 Ian not one of your better vids...thats a real shame. I do hope the price was worth the parts alone. Now what engine will be the better to rebuild...the new 12 horse or the engine in the Raider? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,508 #42 Posted March 11, 2008 Ian, I think at least that engine is rebuildable. Like you said if the crank is salvageable then you have an engine for rebuilding. That crank, from the picture, doesn't look as bad as mine did before I had it rebuilt. I hope your crank can be saved. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #43 Posted March 11, 2008 And you guys must not have caught it, but.... NO BALANCE GEARS! :thumbs: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,508 #44 Posted March 11, 2008 And you guys must not have caught it, but.... NO BALANCE GEARS! Yeah, you're right. And I did not catch it. :imstupid: Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #45 Posted March 11, 2008 Yeah, you're right. And I did not catch it. :imstupid: You -- of all people, Terry -- should have caught that first. Notice there's not even any stub shafts...... I'm guessing the block doesn't even have the holes for them, if my memory is correct. (they weren't drilled unless they originally had the gears) Share this post Link to post Share on other sites
Stigian 1,234 #46 Posted March 11, 2008 Greetings all from my workshop, my first post from down here Ian not one of your better vids...thats a real shame Sorry about that, it was recorded on my camera not the video camera Well spotted the lack of balancer gears its the first thing i looked for when the sump came off. As to which engine will be the best for a rebuild, we shall soon see The raider lump is now sitting on the bench waiting to be opened up after a this coffee (and smoke) break stay tuned for an update :P Share this post Link to post Share on other sites
Greg B. 1 #47 Posted March 11, 2008 Ian, I wish you the best of possibilities, That both engines are rebuildable. Greg B. Share this post Link to post Share on other sites
Stigian 1,234 #48 Posted March 11, 2008 Im a happy bunny again The crank and rod in the K241 are in good condition with only a very slight score mark, you can feel it under your finger but i cant catch a nail in it The bore looks quite good though i have no way of measuring how round it is. Oh no balancer gears , 1 less thing to cause problems I will post some photo's later when im at a pc with a card reader. Catch you all later, im off to order new rings and a gasket set :D Share this post Link to post Share on other sites
Mith 2 #49 Posted March 11, 2008 Unfortunate on the old engine, youve got your moneys worth in parts easily though. Now you just gotta find one with good internals but a broken carb or something. Share this post Link to post Share on other sites
Rollerman 290 #50 Posted March 11, 2008 Sorry about that, it was recorded on my camera not the video camera Ian the vid was good as usual...only ment a let down to see the insides of your new engine that way. Like Jim says...now if you could find another one rebuilt but with broken carb, broke fuel pump, & no tin..... :thumbs: Share this post Link to post Share on other sites
