Gerry w 2 #51 Posted April 23, 2010 This thing isn't the same tractor I hauled down to you.........WOW!! I've been more then happy to help, those rims were rough but I knew you would have no trouble making them shine again. Impressive post Charlie, and I'd love to take you up on the offer of driving it someday!! Share this post Link to post Share on other sites
clintonnut 126 #52 Posted April 24, 2010 Gerry, Here's your rims all cleaned up! Can't wait to mount them! Charlie Share this post Link to post Share on other sites
Gerry w 2 #53 Posted April 24, 2010 :omg: Those cant be the same rims!!! WOW!!! nice job Charlie! Share this post Link to post Share on other sites
clintonnut 126 #54 Posted May 2, 2010 I didn't get any pictures (I know they are worth a thousand words) So heres a bunch of words. Engine: Ready to be assembled (still need .003 rings) Transmission: 8 pinion diff installed, assembled and mounted back on frame so I could continue mock up. Still waiting on hubs from pond19552003 Steering: Steering box mounted with modified bracket Body: Got fenders from Kelly (Thank You!) mocked them up on tractor looks awesome. Got metal to make weight box. Cut tube out of frame that used to support the original fenders. Will add a foot rest bar to mount pedal on and to support C series footrests. Sandblast on thursday, paint friday. Simple as that. Assemble next week to get done on May 15th! (hopefully) Pictures to come! Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #55 Posted May 2, 2010 Sandblast on thursday, paint friday. Simple as that. Assemble next week to get done on May 15th! (hopefully) Forgive me for asking, but - with the extensive modifications you are doing to make this a puller - wouldn't you think it would be wise to put this tractor completely together and try it out before you worry about blasting and painting? Share this post Link to post Share on other sites
clintonnut 126 #56 Posted May 2, 2010 TT, I've torn this tractor completly apart and put it back together 3 times to make sure everything works. This job isn't nearly as hard as my dad and I scratch building a sandrail. We know what we are doing Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #57 Posted May 2, 2010 So..... how far did it pull the sled? Share this post Link to post Share on other sites
clintonnut 126 #58 Posted May 2, 2010 This thing hasn't even moved under its own power yet but this is the third puller I've built and I mainly make sure there isn't any rubbing and binding when I test parts out. I haven't run into anything that hard yet but it requires a lot of mock ups and tear downs. The tractor was completely disassembled and now it is back together for fabrication of the weight box. I am also creating a custom drive assembly for it. It will have a hand clutch that works separate from the brake. Here's what's left to do for fabrication: Weight box, tie rods, hitch, clutch linkage and brake linkage, grille shell and fuel tank brackets. Share this post Link to post Share on other sites
Gerry w 2 #59 Posted May 2, 2010 Having seen your and your Dads' work up close and in person I have no doubt your rig will kick a$$ when it's time comes. Can't wait to see the finished product. We are all "pulling" for you! :D Share this post Link to post Share on other sites
rickv1957 72 #60 Posted May 2, 2010 Charlie,no doubt the your puller will kick some a$$ when completed! Rick Share this post Link to post Share on other sites
chris11 184 #61 Posted May 3, 2010 Charlie keep up the great work. lets see more pictures :D Share this post Link to post Share on other sites
josh416 2 #62 Posted May 4, 2010 hey i came up with a name for it when its done......... how about COW PLOP cause that goes with the tractor perfectley :D Share this post Link to post Share on other sites
Gerry w 2 #63 Posted May 13, 2010 Any "new" news Charlie??? :D Share this post Link to post Share on other sites
clintonnut 126 #65 Posted May 14, 2010 I've been busy lately and it is held up until I get hubs. Charlie Share this post Link to post Share on other sites
clintonnut 126 #66 Posted May 31, 2010 Finally got around to working on this brute today. I washed the engine block 3 times and went through it with an air hose until it was clean of any sand and dirt from the sandblasting. First I put the valves in then everything else followed. Got the short block assembled and it looks great and turns over nicely. I have to thank Josh 416 for most of the parts. Out of trading I got a magnum piston(almost better than billet pistons), camshaft, magnum connecting rod(same as 16hp rod but it is thicker), and rings. As for the tractor we are almost done constructing the weight box and I decided to give you a couple pictures of what the tractor looks like with the big ag tires. Enjoy! Charlie Share this post Link to post Share on other sites
chris11 184 #67 Posted May 31, 2010 Charlie looks great, nice job on the engine. keep up the great work man. :D Share this post Link to post Share on other sites
clintonnut 126 #68 Posted May 31, 2010 Well, the pace has picked up. The frame is almost done modification, the weight box is done, fenders mounted, tie rod made and engine ready for paint! Block ready for paint: Mock up pics. This is probably the 10th mockup we've done of this tractor to make sure everything is right. BTW we bought hubs off ebay so we could roll it around! Charlie Share this post Link to post Share on other sites
rickv1957 72 #69 Posted May 31, 2010 Tractor looks mean!,tires also look great, Rick Share this post Link to post Share on other sites
chris11 184 #70 Posted May 31, 2010 Are you going to sand blast the parts?Looking good. those rear fenders Case ?? Share this post Link to post Share on other sites
clintonnut 126 #71 Posted May 31, 2010 Yes everything will be sandblasted. We just don't like bare metal lying around if it isn't painted right away. Those are GT-14 fenders from Kelly. Charlie Share this post Link to post Share on other sites
VinsRJ 723 #72 Posted June 1, 2010 Charlie, is this baby going to make it to the show? 1 Share this post Link to post Share on other sites
clintonnut 126 #73 Posted June 1, 2010 YOUBETCHA!!! Share this post Link to post Share on other sites
clintonnut 126 #74 Posted June 2, 2010 Well sprayed some red today! Very little is left to do and two weeks from now it should be done! All that's left to do is sanblast the frame and hood with the fenders and weight box and do a couple other minor things! Charlie Share this post Link to post Share on other sites
chris11 184 #75 Posted June 2, 2010 Wow you are flying. cant wait to see it done. wish mine was getting paint now. Share this post Link to post Share on other sites
