Dale 0 #1 Posted December 28, 2009 Im having a hard time deciding which one to fix up. i like the C-161 because it has a hydro lift but i like the manual trans better. if i could find a electic lift for the radier my mind would be made. i have some money saved up to get started just can't make my mind up. i would like to have one good tractor and an ok back up. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #2 Posted December 28, 2009 What do you plan on using the tractor for? Share this post Link to post Share on other sites
baerpath 517 #3 Posted December 28, 2009 So use hyd lift on the Raider. JD used hyd lift on there standard trans tractors. A small tank a starter gen pully and bracket a pump some welding a lift sytem from a hydro and your done. I have a picture of one done nicely have to find it Duane Share this post Link to post Share on other sites
Dale 0 #4 Posted December 28, 2009 mostly garden work pulling a moldboard plow, potatoe plow, hauling wood to the house with a cart. i have a plow on my truck so i wouldn't be pushing that much snow. seams like a moldboard plow puts alot of stress on the dash tower with a manual lift. Share this post Link to post Share on other sites
Dale 0 #5 Posted December 28, 2009 i thought about doing that using a dodge power steering pump Share this post Link to post Share on other sites
wheel horse 1045 2 #6 Posted December 28, 2009 i use my hydro c160 with a moldboard plow and a tiller and even snow blowing and its a beast,my only setback is with tilling because its harder to keep the hydro slow enough for tilling only because i prefer the low range of the 8 speed for tilling,hope that hekped you Share this post Link to post Share on other sites
Bow_Extreme 544 #7 Posted December 28, 2009 I'd make both work for me. It all depends on condition of the tractors and their specific uses. I like to keep my uses versatile depending on the situation. Start with one and than work to the next as funds allow. Share this post Link to post Share on other sites
