C.M.C-175
C Series Engine Mount Plate
C.M.C-175
Are all C-Series engine mount plates the same except for the location of the bolt holes for the actual engine to mount on? I am repowering a C-175 with a Briggs and I will probably have to drill new holes to mount the Briggs engine to the plate, but was wondering if everything else is the same as far as the plate to frame mounting etc.?
rickv1957
I beleive all the mounts should be the same,Rick
baerpath
The Onan and Kohler plates are the same height, The ones for Briggs and tecumseh are riser ones that lift the engine about an inch.
When we put the twin briggs on the C165 we just bought a plate from our local dealer. Just looked up one for a C161 with a briggs
Might also might depend if your using an L head or a V twin ? Ours has a L
Duane
C.M.C-175
Hey Thanks! I just looked up the engine cradle for a C-161 with a Briggs engine on Toro's parts website and apparently that part #106506 engine cradle is not available through the dealer anymore. I'll bet that is going to be a bear o find one of those used.
baerpath
My mistake
Look up A1-16B801 a GT 1600 Workhorse with a twin briggs. Thats the plate we used. If it's not avaliable it will give you a idea of the shape. I'm not sure what Gator used when he put the V twin in his 520. Maybe he'll jump in
Duane
C.M.C-175
Just looked up the engine cradles for the Workhorse. Those engine cradles are still available, but it lists two different model numbers. The one is part # 110065 - Base Engine *R & the other is part # 109534 Base Engine. I am assuming that the Base Engine # is for the single cylinder Kohler and the Base Engine *R is for the Briggs twin. Would that be correct? There is quite a price difference between the two, I wonder what the difference is, unless its the height difference between the Kohler and the Briggs. :notworthy:
TT
I used a 1982 GT-1142 engine riser/adapter plate under my Vanguard twin on the C-85 "experiment".
Sacrificing the rubber-mounted engine is no big deal - especially since the V twin is quite smooth compared to an opposed twin.
Craig - track Kelly down and see if he still has the mounting plate from the GT-1800/1848 he recently parted out.
tarcoleo
Looking at the photo of the GT-1142 engine riser/adapter plate above,
it appears that the actual height of the engine mounting surface above the
frame is no different than it is with the vibration-isolating base plates found
in my C-111 and C-81 units. The GT-1142 unit appears to be rigid and does
not isolate engine vibration. Maybe with greater power, restricting engine
movement may be important.
Tom in Little Compton, RI :notworthy:
wheelhorsec85
hi the engine plate that tt is showing is the one you need . i have one if you are interested just call me at 860-716-9428 jeff
baerpath
The newer twin engined one's all used solid mount. The GT twins 1600 and 1800 417/418/420- 500 series The C195 mounted straight to the frame and a peice of angle iron bolted to the side of it
C.M.C-175
Thanks everyone, you guys are awesome!
Daddy Don
They are the same. I went from a briggs to a kol on a c111. The mount is the same.
