rickv1957
Allis Chalmers
rickv1957
Any of you guys know much about the old AC B Series tractors?,Rick
perry
what do you need to know ?
You'll take the extra leisure the B-10 gives you for really enjoying your lawn and garden. The complete set of attachments, easy fingertip controls and fast hookup make B-10 gardening fun. The B-10 is a quality-built tractor from the folks who build the big ones.
STANDARD EQUIPMENT - Four-cycle (Briggs & Stratton) air-cooled gasoline engine with "oil foam"' air cleaner; 12-volt electric system; electric starter-generator; magneto ignition; key ignition switch; push-button starting; controlled traction differential; three forward and one reverse speeds; drawbar; foot-operated clutch and brake; foam-rubber seat, arms and back rest; footrest; fenders; implement lift system; 2 PTO centers; 4.80 x 8 (2-ply) front tires, 8.00 x 12 (2-ply) rear tires; hinged seat and hood; painted yellow.
OPTIONAL EQUIPMENT - Dual rear wheels; speed reduction drive; hitch adapter; PTO Center Mount; front counterweight; rear counterweight; Auxiliary weight; rear wheel weights: tire chains (8.00 x 12); electric lights. Dual lift control lever; chrome hub caps.
MODEL B-10
ENGINE:
Make Briggs & Stratton
Type 4 cycle--air-cooled
Horsepower 9
Torque 15.75 ft. lbs @ 2400 RPM
Bore and Stroke 3" x 3
rydogg
I don't know a lot about them but I do own an Allis B-210
rustbucket
I am slowly learning that the allis B-110 i got is a heck of a tank and a heavy little machine.
hm12460
yes, they certainly are, wouldn't mind having one of those myself.
rickv1957
I thinking I would like to have an older AC,Rick
TJ
There is an AC right around the corner from me that I have been trying to buy for the last six months. I think they are hoping I will show up with a grocery bag full of twenty dollar bills. If I could do that, I woudn't be living around the corner from them.
Tom
rickv1957
Tom,sometimes people think their things are gold,Rick
perry
ok, fill me in on the lever that you have on the right lift hardware :notworthy: ?
rydogg
The PO removed the hydraulic lift parts and that lever is what he put on to lift the deck. I am trying to find affordable parts to put the hydraulic lift back on. This was the tractor that started my garden tractor collection.
rickv1957
Thats a pretty nice B210 you have!,Rick
dadstractor1
you had better buy that one before somebody else does :notworthy: dadstractor
rickv1957
Howard,your probably right,I should !!!,Rick
rydogg
Thanks Rick, you have a very nice collection going, I have to sit back from my keyboard to keep from drooling on it when I look at the picture :notworthy:
