64s
Bearing and Seal Separation?????
64s
I'm putting together a three speed transaxle and was installing new seals all around. I noticed that the axle seals sit on top of the bearings as does the break drum seal. But as for the pulley seal, if I install it even with the top of the case, there is about an 1/8 to 3/16 gap to the roller bearing. Is this normal, or has the bearing worked itself down a little. If its down, any good suggestions to get it back into position???
Thanks guys, George :notworthy:
64s
ANYBODY??????
rick
George, I have never been where you are, but I would just put the seal in and not worry....If the bearing moved on it's own, it would be unusual.
rickv1957
With a small gap I think you will be fine,Rick
oldandred
its fine puter back together as long as the shaft isnt moving around up and down or side ways
tgranthamfd
That is the way it was on my 60 Suburban 400. I just left the seal flush with the case, hope that is the way it was suposed to be. My old seal was thicker than the replacement I found. Good luck with it.
