diroy21 0 #1 Posted December 17, 2009 I need help. I have a Toro Wheel Horse 265H...Model #72050...Serial #200000454...16 hp engine and it's a vertical engine. I need to replace the electric pto assembly. The bearing is noisy. I have ordered a new assembly. I need to know what to do to remove the old assembly.Thanks! :notworthy: Share this post Link to post Share on other sites
rickv1957 73 #2 Posted December 17, 2009 The older clutchs were threaded after removing retainer bolt you could install a 5/8" bolt and remove clutch ,check yours for the large threads,Rick Share this post Link to post Share on other sites
squonk 42,554 #3 Posted June 8, 2010 on my Gt-14 I had to use a 1" bolt :D Share this post Link to post Share on other sites
oneroadkingman 53 #4 Posted May 5, 2011 i have the same issue with mine has one bolt that goes thru the center .un plug wires remove the guard that's all [its noisy]is there any lube that can be sprayed on it to make it quite again ?it still works ok..just a little noisy. thanks. Share this post Link to post Share on other sites
Kelly 1,030 #5 Posted May 6, 2011 The bearings are sealed, so lube will not help, many can be rebuilt with new bearings, and some times they need the tin guard tweeked or adjusted, they sometimes rub. Share this post Link to post Share on other sites
