~ETC~
UNI DRIVE QUESTIONS
~ETC~
OK i have 2 wheel horses.
a b-111 and a b-81 both have the 4 speed uni drive
both have sloppy/wobbly axle shafts
were there once bearings in the ends of the axle housings or just metal sleeves?
how have others repaired this sort of problem?
on both WHs when i tore the transmissions apart i found remnants of possible bearing cases/ sleeves their so far gone i cannot tell what they once were
Save Old Iron
I just guessing here -
but the bearings and bushings probably disappeared somewhere along this timeline -
from your website
how have others repaired / avoided this problem ??
not this way, wee laddie.
(again, from your website)
use your model and serial numbers - go to the toro website and order / download a repair manual for the transmissions.
search this site for bearing and seal replacement part #'s that can be ordered from NAPA or TORO
Coadster32
Cool pics but..... I don't think by destroying tractors, you'll make ton of freinds on this site. :notworthy: Good luck.
JimD
on the other hand, he may have parts for sale shortly....stirthepot.gif smiley-laughing013.gif
to answer the op's question, yes there were definitely bearings there before.
chris11
well one thing is the top picture the engine is sitting the right way
rickv1957
I guess that is one way to change to a horizonal shaft!,Rick
sawhorse
In other words, you have taken two wheel horses hostage. In order for
them to be returned unharmed, we need to disclose the information.
~ETC~
THE REASON WHY IM RESTORING MY SECOND WH IS BECAUSE THE FIRST ONE (THE BLACK/RED/ORANGE ONE PICTURED) HAS SURVIVED SO MUCH.
where can i buy the bearings? and how are they installed
chazm
Dude ...like it said in an earlier post :notworthy:
  Quote
:thumbs:
Buzz
According to Toro's website, both the B-81 and the B-111 have Peerless 669 transmissions, not Unidrives. I don't know if you can get parts to rebuild them or if it would be worthwhile :notworthy: . You can always download a manual to see if it's something you'd want to try.
TT
Illustrated Parts List (.pdf file)
Some parts are still available through authorized Tecumseh dealers.
