Electro12WH 50 #1 Posted December 3, 2009 Brian Miller's website has a wealth of information, but it's been around a long time. Are there any new tricks for building an engine that he hasn't covered? He can't be the only authority. Share this post Link to post Share on other sites
Curmudgeon 28 #2 Posted December 6, 2009 Some darn place I have a link to a build of a K-301 that has some good points to it. Can I find it? Even after a couple days looking. What I can remember is related to cooling. Carefully file out the ridges between the fins, especially in the area between the valves and cylinder. Air flow there is already limited, improve it any way you can. The other thing was, bead blast the head to get it perfectly clean, but leave it unpainted. It's aluminum, not going to rust, and the paint just provides a bit of insulation effect. Besides, I think it would look cool without the head painted! Racy looking. There were other bits about polishing the crank, etc., usual hot rod stuff. I also have a PDF somewhere of the build, IF I can find that, I can email it to you if you'd like. Share this post Link to post Share on other sites
Curmudgeon 28 #3 Posted December 6, 2009 Pictures are missing, but here are the words: Building a Hot-Rod Kohler K301 For an IH Cub Cadet Garden Tractor Posted by David Kirk on 5-29-01 through 5-31-01 Loud pipes save lives! Actually, this picture shows the first test run of a modified Kohler K301 I built up for my 1250 Cub Cadet. It was a winter project, so I took my time and put together a hot rod Kohler, something I've wanted to do for a long time. The modifications are typical for L-head (flathead) engines and in this article I'll try and describe what I did and show pictures of the parts as the engine went together. Now the obvious question is "why not install a K321 (14 hp) or K341 (16 hp) engine if you wanted more power? Share this post Link to post Share on other sites
Electro12WH 50 #4 Posted December 6, 2009 Thanks! I have Kirk's build of his Cub. There are three parts to it. Good idea with the fins. Share this post Link to post Share on other sites
