Indy w h
E-tank
Indy w h
Ok as everone knows I'm going to attempt the e-tank I was wondering if I e-tank
my 702's hood stand do I take-off the shift/ser. Tag or let it come off in the tank???
Thanks Indy
linen beige
Just let it come off in the tank if it will. The solution shouldn't hurt it.
Indy w h
Thanks Jim I'll give it a shot
Indy
Save Old Iron
Indy,
as long as you do not have any aluminum or chrome plated parts on that assembly
and you using a standard washing soda electrolyte ( no lye, etc)
you should be OK
also, make sure any pieces bolted together have good electrical contact or one piece will derust and the other one without the electrical contact will not process out as you would expect
:notworthy:
Indy w h
So what is the tag made of???
Indy
Rollerman
It's early & the brains still sleeping in so thats my get out of jail card if I'm giveing you incorect info. :notworthy:
I'd copy the model/serial number down before soaking it & you will probably lose it when the paint under it lifts away from the metal.
If I recall dunking one of my tractors with that style of tag....almost like adhsive backed foil...the tag was washed clear from the E process.
Indy w h
Hey Stephen I think your right it is a foil of some sort. This is my 1st restore and I'm wanting to keep the tag(if I can),and also 1st e-tank try out. Wish me luck!!
Indy
Save Old Iron
Indy,
maybe try heating the foil with a hair dryer, lift one edge will a dulled razor blade and then gently peel back the rest of the foil while applying heat from the dryer - its worth a try
:notworthy:
