jdog_kustoms
electrolysis rust removal
jdog_kustoms
i am lookin at seting up and electrolysis with a 330 gallon plastic tote with metal frame on skid gona make a inside cage out or 3/8 inch rebar on all 4 corners and one per side and 4 across the bottom all welded together so i can do hoods frames engines pretty easily
i have read alot of posts but i have one question
can i use a miller arc welder on dc voltage and around 20 amps or will this be over kill i am lookin at one for $100 with leather chaps coat sleaves 2 pair of gloves 2 helmets lots of rods and extra cable hell of a price or should i go get a big battery charger
thanks for all your help
Save Old Iron
JDOG,
DC volts is DC volts - same from a battery charger or a welder.
The only caution that comes to mind is the open electrode voltage produced by some welders can be high enough to lead to a very SHOCKING experience if you forget to turn off the welder to clean the electrodes. Family, friends and pets seem to love the E tanks !! :notworthy:
I have a "special tank" I use for quick derusting that uses 40volts @ 4 - 5 amps. Blasts off the paint and grease - produces a tremendous amount of off gasses and blows away rebar anodes very quickly. It heats the water in the E tank to over 100 degrees and must be monitored constantly so no one else has a chance to mess with it. If you short out the electrodes in this tank, you will hear a pop from the hydrogen surrounding the tank.
Not for the faint of heart and not for indoor use !!
Don1977
Welders come in AC and DC output. Are you sure it's DC. DC welders are usually bigger and more expensive.
