Daddy Don 912 #1 Posted November 22, 2009 OK, the hub is now off thanks to a saws all... We need some guidance, how do we remove the wheel seals with the axles in place? Share this post Link to post Share on other sites
Lane Ranger 12,094 #2 Posted November 22, 2009 Don: Here is a link to a good deal of oil seal removal and installation information! Nana and/or any good auto store sells a cheap oil seal pick to remove one. You can use an old ice pick -just bend a little hook in the end of it to get under the old oil seal and remove it. Usually they are so worn if they are leaking that they come right out with no trouble. The replacing part is also a little tricky as you want that seal to go in the shaft around the axle without damaging the metal portion of the seal. The two links below should help you. If you don't have the answers you need just ask again on Red Square. A lot os us have done this job already on our old Wheel Horses! http://www.wheelhorseforum.com/index.php?...=0entry100423 http://www.wheelhorseforum.com/index.php?...=0entry100423 Share this post Link to post Share on other sites
tarcoleo 120 #3 Posted November 22, 2009 Don- You should be able to dig out the old seal with a sharp pointy tool, like a scriber or ice pick. Tom in RI Share this post Link to post Share on other sites
MaineDad 87 #4 Posted November 22, 2009 Sears sells a seal pick - great to have in the tool box Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted November 22, 2009 I have a old screwdriver that is custom made, with a point and hook on the end, I normaly punch a hole in the metal part hook it and pull them out, I use the boxed end of a end wrench to tap on when installing them, a piece of pipe the right size will work too. oh ya make sure you polish the shaft,(may have to file around the key slot) and grease it before putting the new seal in, so you don't mess it up. Share this post Link to post Share on other sites
mnWHfan 47 #6 Posted November 23, 2009 A trick that I used to install the seal over the shaft was to wrap a piece of tape around the shaft so that it covers the keyway and then apply some oil over the tape before you slide the seal over it. This worked really well on my transaxle. Share this post Link to post Share on other sites
wheelhorsecravins 0 #7 Posted November 23, 2009 Hi , jumping in here, where can I get new axel seals for a R J 58/59 ??? thanks mike Share this post Link to post Share on other sites
Sarge 3,473 #8 Posted November 23, 2009 Seal removal, as per "oldest trick in the book" - Drill 1/8" hole in the seal perimeter lip (steel part), insert small sheetmetal screw tight. Using either a small forked prybar you can easily pry it out. Some require a screw on each side. Also, have used a pair of dikes on the screw head and a solid hit from a hammer works good.... Sarge Share this post Link to post Share on other sites
Daddy Don 912 #9 Posted November 23, 2009 Hi , jumping in here, where can I get new axel seals for a R J 58/59 ??? thanks mike I got mine from Toro for the c111 you might check with them and see if they have them. Share this post Link to post Share on other sites
Lane Ranger 12,094 #10 Posted November 23, 2009 Best way to find the seals you need to repair or maintain your wheel horse: 1) Check you manual for the original Seal number. 2) Go to the SKF/Chicago Rawhide website and place the origianl Wheel Horse seal number in the site. Here is the link: http://www2.chicago-rawhide.com/popup_part...okup_457012.htm 3) After you get the New SKF number you can take that to several auto stores for a seal. I use NAPA and they can get in two days. The seals are a lot cheaper (and just as good of quality) as Toro will sell you). :notworthy: Share this post Link to post Share on other sites
rickv1957 77 #11 Posted November 23, 2009 may have a set of seals for a RJ just give me a part number,Rick Share this post Link to post Share on other sites
wheelhorsecravins 0 #12 Posted November 24, 2009 thanks Rick , I will try to find a # on the old seals when I pull them, I don't have a manual, also while we are at it the keys on the rear hubs are worn, they fit sung in the hubs and are loose on the axel shafts, what should I do to fix, thanks for any help, mike P S also thanks to Lane Ranger and daddy don. I will try that also. mike Share this post Link to post Share on other sites
dadstractor1 5 #13 Posted November 24, 2009 rick part number fore rj58 59 is1232 dadstractor1 :notworthy: Share this post Link to post Share on other sites
tarcoleo 120 #14 Posted November 24, 2009 Wheel seals are available at NAPA- 1" is PN CR9815 1-1/8" is PN CR 11050 Thanks to a previous post by a good soul whose name I don't recall. Tom in RI :notworthy: Share this post Link to post Share on other sites
Prater 78 #15 Posted November 24, 2009 Wheel seals are available at NAPA- 1" is PN CR9815 1-1/8" is PN CR 11050 Thanks to a previous post by a good soul whose name I don't recall. Tom in RI I did not find the seal by that part number, but I did find a seal under this part number. It is a NAPA oil seal Part #NOS 11050. Is that the one I need for my 1 1/8 tranny? NAPA says that is a Pitman Arm shaft seal if that helps. I am sure it is the same oil seal but just want to make sure before I order. Share this post Link to post Share on other sites
wallfish 20,571 #16 Posted November 24, 2009 From my understanding the CR/SKF seals for the axel won't fit properly for the RJ tranny. The input and brake shaft seals are a common seal and can be bought fairly cheap. I know MikesRJ and Fireman ended up with Toro seals for the axels after searching for replacements. You could do a search here and find the threads that they posted about it. Share this post Link to post Share on other sites
tarcoleo 120 #17 Posted November 24, 2009 Oklahoma Steven- I installed the NAPA 1-1/8" Part No. CR 11050 in my C-81. No worries. Cost less than $6.00. Tom in RI Share this post Link to post Share on other sites
sorekiwi 761 #18 Posted November 25, 2009 This thread is getting confusing... The RJ seal is a different kettle of fish than the common seals found in most of the other transaxles. Most of the posts in this thread are talking about the common seals for the 1 and 1 1/8 axles. These are available from Napa and bearing houses. The other half of the posts in this thread are talking about RJ seals, which I understand as being different. There was a thread not long ago about RJ/Suburban seals. A search will uncover it. Share this post Link to post Share on other sites
Prater 78 #19 Posted November 25, 2009 I ordered the NAPA seals. i may try to run by there and pick them up in the morning and compare them to Dads TORO seals. Share this post Link to post Share on other sites
Prater 78 #20 Posted November 27, 2009 Dad brought over his Toro part number 110509 wheel seals. I compared them to the NAPA NOS11050 seal and they are the same dimension. The NAPA seal actually looks better than the TORO seal. The TORO seal looks like cheap plastic casing and the NAPA seal is a metal casing. Share this post Link to post Share on other sites
tarcoleo 120 #21 Posted November 27, 2009 Daddy Don in Okla. Just wondering about your hub problem. Might you have freed up the hub on the axle by pounding the hub inboard before attempting to pull it off? Or did you? Also, the Woodruff key installation is important after all is said and done. The key supposedly is a USA standard #812, but in ordering one last week it was found to be too large in height above the axle slot. After grinding down, the proper total height is a bit more than 0.5 in. Grind and try to find just the right height so as to avoid problems later. You should be able to drive the hub over the key onto the axle with only a little persuasion. Hope this helps, Tom in RI Share this post Link to post Share on other sites
Prater 78 #22 Posted November 27, 2009 That hub would not budge either direction. We applied heat, oil, wax. Everything in the book. It did not move a fraction. Even our 12 ton puller would not budge it. Share this post Link to post Share on other sites
tarcoleo 120 #23 Posted November 27, 2009 Guess you gave it everything. Tom :notworthy: Share this post Link to post Share on other sites
Daddy Don 912 #24 Posted December 13, 2009 Replaced the seals today. It was easy. I drilled a small hole on each side and then took the pick and pulled them right out. Used an old hub to drive the new ones back in. Make sure they are all the way in. I cleaned the shaft with WD-40 and 100 grit paper. It worked great. Thanks for everyones help. :notworthy: Share this post Link to post Share on other sites
