HorseBreaker
Hi-Low range problem
HorseBreaker
Hi Guys: I'm brand new to this forum but it looks great. I've been running a C121 for years doing a bit of contract work with it, from the day I bought it the transmission was noisey but it never got any worse.
A few months ago I had the chance of a C125 which I thought would be great for spares, I bought it but when I got it home I found the 8 speed transmission had no low range, not knowing what the problem was & fearing bit of metal loose in the bottom, I decided to dismantle the unit.
I took advice from a local Wheel Horse Repair Shop Manager who told me I would have to be very dedicated to attempt the operation.
Not being one to be beaten without a fight I removed the unit & dismantled it which was surprisingly straight forward.
The range selector was unfortunately one of the very last components to be removed from the case, but the problem was easily fixed.
I have now repaired two of these transmissions with with the same problem.
The range selector fork is made of what appears to be mild steel which is welded to a mild steel sleeve which slides onto a shaft, the fault is that this component breaks, probably from the shift being forced, the remedy is to weld it back together or buy a new selector which I am told is around
Save Old Iron
:notworthy:
KB9LOR
Nice info, will be sure to add to my repair info drawer!
:notworthy:
chazm
:WRS: :):banghead:
:notworthy: for the info
Chaz :thumbs:
WHC-125
:notworthy:
Duff
HorseBreaker, :thumbs: ! Glad you found us, and thanks for the tip!
BTW, where do you hail from?
Duff :notworthy:
Indy w h
Hey :notworthy: glad you joined
Indy
Coadster32
:notworthy: Pretty darn good first post if you ask me! Thanks for the tip.
tgranthamfd
:notworthy: And thanks for the information.
bitten
Hello and :notworthy:
Polaris2007
Yep, Horsebreaker is right on the money. The EXACT SAME thing happened to my '77 C-120 8-speed. I disected it, changed all the seals and gaskets, installed the new shift fork (cost about $30) and I was good to go.
