benc160 0 #1 Posted October 31, 2009 Hi guys, I am restoring my grandpa's 1975 C-160 Auto w/ hydralic lift. I found a few cracks in the transaxle case were I believe someone at one time used to long of a bolt to attach the hydralic motor to the case. I would like to find a parts tractor to replace the case. I have found an 8 speed tractor on craigslist and wanted to make sure the 8 speeds and autos used the same transaxle assembly. Any information would be helpful! thanks, Ben Share this post Link to post Share on other sites
baerpath 517 #2 Posted October 31, 2009 The 8spd case is totally different If your close by I have a trans from a C120 hydro. I'm in Canajoharie NY Duane Share this post Link to post Share on other sites
Duff 206 #3 Posted November 1, 2009 Hi, Ben! ! The guys here will get you squared around. Glad you found us! Duff :scratchead: Share this post Link to post Share on other sites
benc160 0 #4 Posted November 1, 2009 Thanks for the information and offer, Duane, but I am located in north eastern ohio. I'm not really in a big hurry on this project so i'll keep looking around here. Thanks, Ben Share this post Link to post Share on other sites
kpinnc 13,524 #5 Posted November 2, 2009 A mechanical tranny will directly bolt into a tractor that was a hydro, but you'll need all the other parts that make it work- clutch pedal, clutch and brake rods, different brake band, etc... On a 1975 model you may need to change the entire center console/ fender pan support. If you have a donor machine of the same general vintage you'll have all the parts, but it isn't just a 30 minute job. It is much easier on a newer model. Good luck! Kevin Share this post Link to post Share on other sites
can whlvr 993 #6 Posted November 2, 2009 if possible i would keep that machine an auto,the good thing is you didnt say the hydro was toast,so maybe you can find a trashed pump with a good transaxel and get it cheap,its not too hard to swap out the uni drive and put your pump on it,dont forget to get a new gasket which are still available. Share this post Link to post Share on other sites
benc160 0 #7 Posted November 2, 2009 Yes I plan to keep this tractor an automatic for sure. The hydrostatic transmissions are the best for mowing in close quarters since you can change directions and speeds quickly. My pump works good, but after the tractor warms up the hydralic lift is slow. The major "hard parts" in the hydrostatic unit are in good shape but I am going though it to replace all of the orings and seals. -Ben Share this post Link to post Share on other sites
