chris11 184 #1 Posted October 29, 2009 Hello All, Im starting a puller build. i was converting my charger 12. into a 8 speed. Thanks to Mike for your help with tran. So im looking to see what i need to do, and there is two cracks in the mount for the tranny. well a friend had this old chassis kicking around so i cut the back off. . ill post pics . Share this post Link to post Share on other sites
Sparky-(Admin) 21,863 #2 Posted October 29, 2009 Hey Chris. If you hit a snag with pic posting send em to me and I'll get em on for ya. Good luck with the build ! Mike........ Share this post Link to post Share on other sites
chris11 184 #3 Posted October 30, 2009 heres the rear plate Attached Image Share this post Link to post Share on other sites
bitten 134 #4 Posted October 30, 2009 Chris That happens. Repair the cracks and weld a 1/4" plate to the other side of frame that tranny attaches to. Make your plate big enough to weld to the angle iron frame and cover the tranny footprint. Drill your holes and add longer bolts. Some people add a brace running from the frame rails to the bottom of the plate that was welded in. Good Luck, P.J. Share this post Link to post Share on other sites
chris11 184 #6 Posted November 2, 2009 Well i got a rear plate off a old bent frame, as i was cutting it off. i was thinking i could make a complete new frame. i had some 2 inch angle so im going to make it 4 inches longer. Share this post Link to post Share on other sites
chris11 184 #7 Posted November 6, 2009 Im having a hard time up loading pics. heres the frame as of now Share this post Link to post Share on other sites
chris11 184 #8 Posted November 15, 2009 I picked up most of the parts i needed from Tony. Blasting parts getting them ready for paint. Share this post Link to post Share on other sites
rickv1957 73 #9 Posted November 15, 2009 Chris,looks like great work there on your frame,Rick Share this post Link to post Share on other sites
KeithB 6 #10 Posted November 16, 2009 very nice work, our clubs here don't allow us to lengthen the frame in stock classes here is my 12 HP stock: 1 Share this post Link to post Share on other sites
MRM 4 #11 Posted November 17, 2009 What kind of pulling will you be doing? Stone boat or transfur sled. Most clubs don't allow custom frames they have to be stock, In my area any ways. Our local clubs only pull stone boat. I use a stock C-121 with stock turf tires that is scaled in at 2000lbs. on a good clay track i can pull 6000lbs. Only blew the 8spd once and it was only a axle bearing that went. Share this post Link to post Share on other sites
chris11 184 #12 Posted November 18, 2009 Ill be doing stone boat. I did end up cutting frame back down to size.Everyone told me to make it the same as stock. 1 Share this post Link to post Share on other sites
chris11 184 #13 Posted November 24, 2009 as you can see I made new steering shafts, and put a bronze bushing in., Now heres some new pictures of the rear , Check out the tail light. filled the seat holes in. also cut corners on front of fenders 2 Share this post Link to post Share on other sites
KeithB 6 #14 Posted November 24, 2009 looking good :notworthy: Share this post Link to post Share on other sites
Sparky-(Admin) 21,863 #15 Posted November 25, 2009 Chris. That tail light is HOT!! What a cool modification. Mike....... Share this post Link to post Share on other sites
rickv1957 73 #16 Posted November 25, 2009 Chris,your tractor is looking very good,great work,Rick Share this post Link to post Share on other sites
WHC-125 4 #17 Posted November 25, 2009 Chris, really nice work!!! And great craftsmanship on the tail light! :notworthy: Share this post Link to post Share on other sites
whfan74 2,068 #18 Posted November 25, 2009 That is starting to shape up real nice! I agree that tail light looks sweet! :notworthy: Share this post Link to post Share on other sites
dadstractor1 5 #19 Posted November 25, 2009 have pulled horses a lot started with 656 3speed broke a lot put in 8 speed never broke again 12 horse egine had troble keeping frountend down made next one from c 121 12hp does not work well but good luck kick cubs but :) Share this post Link to post Share on other sites
chris11 184 #20 Posted November 25, 2009 Thanks for the coments guys. I got some more mods im going to do. wait till you see the twin carbs Share this post Link to post Share on other sites
chris11 184 #21 Posted January 9, 2010 Sorry for the delay on pictures. I have been busy at work Building a GTO. Also i have Sparky load them for me. Great guy. Anyway i hope you like what i got done so far. :thumbs: Share this post Link to post Share on other sites
Stress Test Pullin 0 #22 Posted January 9, 2010 nice work with the rear light and all, but im curious to know what class your are building this for, and is that a briggs twin? you might want to be cautious with those with a twin carb set up, it doesn't take much to white wash the cylinders in know this the hard wash i post up a pic later of why, but good luck to ya, looks good so far :thumbs: Share this post Link to post Share on other sites
d180man 5 #23 Posted January 9, 2010 heres the rear plate Hi looks like my old one i have but it has 4 cracks but nice work look great keep it up ! :banghead: Share this post Link to post Share on other sites
Sparky-(Admin) 21,863 #24 Posted January 10, 2010 Heres the pics Chris sent me. WAY COOL!! Mike......... 1 Share this post Link to post Share on other sites
chris11 184 #25 Posted January 10, 2010 Im building that twin briggs to take both those carbs. Im building as a puller. but more for fun. i have the new rear ags just got to order rear rims. Paint is going to be base coat clear coat. 62 ferrrari red. i have spare engine to mods too. Thank you Mike Share this post Link to post Share on other sites
