Rogue
6-speed and 8-speed question
Rogue
This may sound silly... But after looking at the tranny manuals I'm having trouble seeing a difference between the following transmissions. Can anyone give me some insight as to why one is referred to as a 6speed and the other an 8 when the ratio's appear to be the same. Also, is there a "better of the two scenario"?
Thank you for any help you may be.
(Pg.32) 5060 6-speed limited slip differential
RATIOS
Gear High Range low Range
1st gear 66.8 to 1 267.2 to 1
2nd gear 42.4 to 1 169.6 to 1
3rd gear 24.6 to 1 98.4 to 1
Reverse 51.5 to 1 206.0 to 1
(Pg.50) 5073 8-speed limited slip differential
RATIOS 8-SPEED TRANSMISSION
TT
Starting in 1973, high and low reverse were counted as "speeds" (no one ever said in what direction "speeds" had to be :scratchead: ) for a grand total of 8.
It's my guess that it was a marketing ploy by WH and nothing more. ("Our transmission has more speeds than brand X.")
With proper maintenance, the most reliable and durable manual transaxle is the 8 speed Uni-Drive with 1 1/8" axles and the 8 pinion differential. They are normally found in the majority of the C series tractors, the 400/500 series and the '76/'77 B-60/80/100 models.
Rogue
Thanks TT :scratchead: I very much appreciate the explaination. One more question... Do you happen to know if the 5060 6-speed is problematic?
TT
If they are properly maintained and used normally (no heavy "jerking" from pulling) they have a very long lifespan. I know of quite a few from the late 60's that are still going strong! :scratchead:
The biggest problem with all 6 & 8 speed transaxles is shifting the range selector without completely stopping which can result in gear damage and/or a bent/broken shift fork.
Rogue
Great information. Very much appreciated.
Thank you.
