KeithB 6 #1 Posted October 16, 2009 I need a very basic wiring diagram for a C-120 with 12 HP Kohler, it has points and coil ignition. This is a GT puller, so only need ignition, start and charging. What I mainly need to know is where the wire from the rectifier plugs on the ignition switch. and how a amp meter ties in. I assume it breaks the wire between the rectifier and the ignition switch? and the pin out of the ignition switch? Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted October 16, 2009 This one should work: The B+ wire from the rectifier goes to the "R" terminal on the switch. Share this post Link to post Share on other sites
KeithB 6 #3 Posted October 16, 2009 Thanks what are the other pin outs on the ing switch? Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted December 5, 2009 R-Regulator A-Accessories (lights etc.) I- Ignition S- Start B-Battery Share this post Link to post Share on other sites
KC9KAS 4,744 #5 Posted December 5, 2009 OOPS! Here is a site that explains it even better: http://www.wheelhorseforum.com/index.php?showtopic=13597 Share this post Link to post Share on other sites
