Alan_Heist
service assembly 105104
Alan_Heist
I got a sleeve hitch kit, and according to the Toro Master Parts viewer I need "service assembly 105104" to install it on my Charger 12, but I can't find anywhere what this assembly contains.
Any help on this one?
Alan_Heist
Based on looking at the hitch parts, this has to be some type of sheet metal assembly that goes in the tool box, or replaces the tool box for the lever assembly from the newer versions of the clevis/sleeve hitch to get put into.
The original version 8-5511 just had a cable that went from the lift lever arm to the hitch assembly. Later versions, starting with 8-5512 up through the current version, 8-5518 or 85518 use the lever assembly, but the tool box is too wide for this lever and also doesn't have the holes needed for it.
Maybe someone has taken one of these out of the tool box section and just doesn't know what they have. If you have one, I'll take it of your hands for a fair price if you're interested in parting with it.
Thanks for looking!!
Alan
WheelHorse_of_course
Not to beat a dead horse.... I am in the same situation. AFAICT the non-lever (8-5511) lift/cable assy will work with the slot hitch or the clevis hitch, but not with the tiller. Does anyone agree?
