KeithB
removing drive pulley from crank?
KeithB
got both set screws out, how do you get the drive pulley to slide off the crank?
Thanks
Indy w h
Hey, Keith
I always use good penatrating lube
a dead blow hammer and a gear pulled
should just pop off. Or if that don't work
try a little heat
tarcoleo
Just did that with a cheap wheel puller. Otherwise would have carefully
pried on two sides, 180- degrees apart, with penetrating oil and TLC.
As someone pointed out recently, make sure there aren't two setscrews
in one hole.
Tom in RI
