nylyon-(Admin) 7,454 #1 Posted September 22, 2009 Hey guys, I would like to start a thread with pictures showing the location of the serial number tag on the various models. Once it is semi complete, I will move this to the FAQ section. I would like to keep this discussion limited to actual pictures and not comments about a post or the topic. I will probably trim this topic before I move it to the FAQ anyway. So who want's to go first? Share this post Link to post Share on other sites
MikesRJ 555 #2 Posted September 22, 2009 1973 Wheel Horse 10 HP - 8 Speed Share this post Link to post Share on other sites
CasualObserver 3,410 #3 Posted September 22, 2009 1963 Model 603 - on shift decal in dash area of hood. 1960 Suburban 400 and 550 - between choke and throttle stamped into steel plate just below top mounting screw. (Also same on early 1961 Suburbans that used the cut off piece of dash plate) 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted September 22, 2009 Many 1965 to 1972 tractors had the tag riveted to the hoodstand just under the aluminum dash housing: Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted September 22, 2009 62-64 Roundhoods with the cast aluminum fuel tank: Share this post Link to post Share on other sites
TJ 183 #6 Posted September 23, 2009 654: decal on left side of control-hood column. Share this post Link to post Share on other sites
gwgdog66 23 #7 Posted September 23, 2009 1975 C-160 8 Speed, left side right above the dial-a-hight. 1983 WorkHorse 1642, Right side right above the belt guard. Share this post Link to post Share on other sites
CasualObserver 3,410 #8 Posted May 20, 2016 So many people ask where to look for serial numbers.... I stumbled across this old post with photos showing locations to try and help people. Thought I'd drag it up. 1 Share this post Link to post Share on other sites
TDF5G 2,072 #9 Posted May 20, 2016 Thank you, I hadn't seen this thread. Share this post Link to post Share on other sites
