Kelly 1,030 #1 Posted September 15, 2009 Can anyone tell me if a hydro trans from a GT 1800 will work in a 518 ? I think it will but not sure, the GT has hyd. lift the 518 does not but that is no big deal, I just need to be sure it will bolt in and linkage will fit correctly, both should be Eaton transmissions I belive 1100's? I don't have model no.s for either tractor. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted September 15, 2009 To my knowledge it should be a nuts & bolts direct swap, Kelly. (The GT-1800 will have an Eaton 1100 series, but the 518 unit is a 700 series.) Share this post Link to post Share on other sites
Kelly 1,030 #3 Posted September 15, 2009 Thanks Terry, I havn't seen the 518 yet I just guessed it would have the 1100, so all linkage should be the same? I need to pull all the parts need to make the swap out of the GT and deliver, I don't want to be short parts. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted September 15, 2009 There aren't any major differences I can think of on the Eaton linkages - other than the column shift version. Will you be installing the hydraulic lift on the 518 too? If not, I'm not sure if you can just plug the ports (probably) or if you have to connect them with a hose. Share this post Link to post Share on other sites
