Bar Nuthin
Aerosol paint can mixer
Bar Nuthin
Ran across a couple videos while looking for a paint shaker and saw this contraption for spray cans. I already had a piece of 3" PVC the right length. Just bought the 3" plug - stupid thing works like magic!!!
  • Like 6
ebinmaine
Interesting concept!
Bar Nuthin
When you stop the drill, you can hear the shaker ball whizzing around inside the can. Can of Rust-Oleum, prolly setting a couple years, sprayed like a dream.
HyperPete
So, the one Adam likes has the shaft slightly off-center to facilitate shaking & mixing through wobble.  How does the one in the 2nd video achieve that?
Sorry, a bit critical, I know.
Bar Nuthin
The pipe is 3" - about a half inch wider than the spray can. The shop rag holds it against the side wall, plus allows you to retrieve the can. If you don't hold on tight, it takes on quite a wobble.
I'm not sure the wobble is as important as the cyclone action it gets from spinning so fast. I don't think the wobble in Adam's video was intentional.
I'll try to get a video of the one I made so you can see it.
Edited by Bar Nuthin
Bar Nuthin
Here's another video.
HyperPete
Well it looks like It works well, and it's obviously very cheap, so I guess I'll have to give this a shot too! I think I have some three inch PVC, all I need is a test plug.
Thanks for posting this!
squonk
I watched the 2nd video. I was hoping he would paint it camo so he would lose it in his shop.
  • Haha 4
953 nut
:angry-tappingfoot:          Shaking a paint can is the best exercise I get some days, why would I want to mechanize it?                        :confusion-confused:
  • Haha 4
Bar Nuthin
Yeah, kinda reminds me of younger days. :ROTF:
  • Haha 1
Bar Nuthin
 All I have to do to lose stuff in the shop is set it down!  My garage isn't very big, but yesterday I spent a half hour looking for a beacon light on a 4' pole. Ended up being right out in the open. :rolleyes:
  • Haha 1
8ntruck
:text-yeahthat:. When I first started working as an e ginger, we had an old, semi retires engi per that had a work room in the product engineering area.  He would come in and tinker with stuff several days a week.  His toom was less than organized.
When he would set something down and loose it, he would take a Poloroid picture of his bench, and look for the item in the picture.  His theory was that the lost item had temporarily rotated into another dimension that we can't see,  but a Poloroid camera could detect.
  • Haha 5
CRF857
I purchased a skill reciprocating saw at a garage sale. The blade mounting component was broken. After finding out i was NLA I turned it into a paint shaker. BIL donated a shoe with velcro straps. If straps are slightly loose the can will rotate while being shaken. Turn it on and walk away for a few minutes. BIL’s shoe was big enough to accommodate the tall cans also.
  • Haha 3
Bar Nuthin
What I was originally searching for was a gallon paint shaker.
Anyone have a good DIY hack?
EB-80/8inPA
Seems a shame to use such a fine looking shoe for a paint shaker.
  • Haha 3
CRF857
It’s current occupation has not been kind to it.:D
  • Haha 2
Beap52
After wasting several partial cans of spray paint because nozzles dried out or got paint caked over them, when I am finished with spraying, I now remove the spray nozzle and blow it out with blow gun on compressor to clear any residual paint. I often times also blow a shot of air into then tube sticking out of the top of the spray can.  I lightly replace the nozzle and I'm ready for the next time.  I sometimes  also soak valves in acetone and the blow them out with compressed air.
Some time ago, on a similar topic, I suggested (at your own risk) to re-pressurize spray can paint that has lost it's pressure.  I have a valve stem that has been cut off and I place the cut off end of valve stem over the tube sticking out of the top of the spray can and using an air chuck blow air into the spray can.  Don't over pressurize the can or we'll be reading about you under "bumps and bruises".   Also, I'll warn  you to wear latex gloves otherwise you'll likely end up with colorful fingers.
HyperPete
An old washing machine, perhaps?
Do you have any spare horizontal shaft engines that you don't have a use for?
I know!  Build an attachment For one of your horses that connects to the PTO.
You'll be rich!
You'll be famous!
(Hopefully you won't be covered in paint!)
  • Haha 2
Beap52
Ahhh! Now I have a reason to buy another Wheelhorse with a shaky Kohler!  Do I cut a hole in the hood and place the bucket of paint on the head or baling wire it to the side of the engine?  Decisions, decisions!
  • Haha 1
HyperPete
I was thinking more of an eccentric pulley, attached by a long, bouncy belt, connected to the rear.
Heck, with that setup, you can drive around on uneven ground to amplify the results!  Your plans would benefit from that, too...
Bar Nuthin
I remember seeing one that was attached to a tractor rim. The guy just drove around his barnyard with a 5 gallon can of paint attached to one of the wheels.
  • Haha 1
HyperPete
I can see some artist doing this on a canvas with a hole in the can.
$62,000!
ebinmaine
Love the ideas and entertainment here but @953 nut has a valid point.
Your muscle & bone structure is very literally  "use it or lose it".
How many cans are we shaking?
If there's a legitimate reason such as  personal physical health or limitation then a mechanical shaker would be a GREAT idea.
But otherwise....  keep using your people chassis or it won't be there when you really need it.
  • Heart 1
squonk
I can't squeeze things with my hands like I used to. I can see the can flying away.
Edited by squonk
  • Confused 1
adsm08
I spent 10 minutes looking for a wrench that was in my pocket Friday.
